Best Scanner for Vehicle survey
Faro FOCUS S350, S150, S70, M70, X30, X130, X130HDR, X330, X330HDR. Leica RTC360, C10, P15, P20, P30, P40, P50, BLK360, HDS6*00, HDS7000,HDS8800, HDS8400. Riegl VZ6000, VZ4000, VZ2000, VZ1000 & VZ400i. Topcon GTL-1000, GLS2200, GLS1500. Trimble X7, X9, X12, SX12, SX10, TX8, TX6, S7 & S9. Z+F IMAGER 5016, 5010X, 5010C, 5006H, 5006EX & PROFILER 9012
hoho
10
Full Name: jan antropius
Company Details: 3DMS
Country: Czech Republic
Post by hoho »
Hi everyone,
i am about to finish a scan project of a bus. We scanned with our Faro X330 (quality 4, resolution 1/4), the poincloud we got from the scanner is not very clean, i supose the surface is too glossy.
Does anyone have good workflow how to clean the clouds of a shiny surphaces using Scene, Cloudcompare or Geomagic?
Does anyone have an experience with similar project, which scanner gives the best results? I think Surphaser should be better for this purpose. Am I right?
Thanks a lot
Jan
dcacioppo
I have made 70-80 posts
8
Full Name: David Cacioppo
Company Details: Park Ridge Police Department
Company Position Title: Patrol Officer and Forensic Technician
Re: Best Scanner for Vehicle survey
Post by dcacioppo »
If you can scan again, you could try reducing the power of the laser on the scanner and/or "dulling" the surface of the bus with a baby powder/rubbing alcohol solution (dry shampoo or foot powder spray also works).
The only option I know of in Scene is manually cleaning up the individual scans.
sooperdooper
10
Full Name: Russell White
Company Details: HTS Advanced Solutions
Company Position Title: Mapping Operations Manager
Post by sooperdooper »
The X330 is a very capable scanner and should have captured it just fine. I too would recommend decreasing the power of the scanner or taking scans further back from the vehicle.
Cranfill.ca
Full Name: Cody Cranfill
Company Details: Construction Engineering
Company Position Title: Scan Technician
Post by Cranfill.ca »
sooperdooper wrote: Mon Mar 19, 2018 1:34 pm The X330 is a very capable scanner and should have captured it just fine. I too would recommend decreasing the power of the scanner or taking scans further back from the vehicle.
How do you decrease the power of the scanner (faro x330)? Do you mean decreasing the " Quality " from 4x to 1-2x or the resolution?
Thanks,
sooperdooper
10
Cranfill.ca wrote: Mon Mar 19, 2018 8:23 pm
Thanks,
Try taking your scans further away from the vehicle first. If needed, you could reduce the quality from 4x to 1x-2x
3DForensics
Honorary Member
Honorary Member
14
Full Name: Eugene Liscio
Skype Name: eliscio
Has thanked: 13 times
Been thanked: 70 times
Post by 3DForensics »
Use the Edge Artifact Filter and it will clean up some of the noise. However, be forewarned that if you don't have enough scan positions, you will likely clean up some good points too.
Eugene
