Scanning in two faces
MedoLedo
Full Name: Medic Tomislav
Company Details: University of Bonn
Company Position Title: PhD student
Post by MedoLedo » Tue May 23, 2017 10:11 am
Hi everyone,
I am making a short survey about the panoramic scanners in the market. I need your experience and help with one question. If and when you have time, can you please answer the following:
*) Which device do you use and can you make measurements in two faces with it? Is it easy or complicated with in built software?
I only have experience with Leica ScanStation P20 and it is quite easy to measure whole surrounding in two-faces. But I am not sure how easily is it done with other scanners. It is very useful information for eventual scanner calibration, deformation monitoring and performance testing of the scanners (for example if you follow development of the new standard test procedures of the American National Institute of Standards and Technology).
I will share with you the summary of the survey once it is completed, if you are interested.
Thank you very much for the help.
Tomislav Medic
anonimou
Full Name: Delio Pontes
Re: Scanning in two faces
Post by anonimou » Tue May 23, 2017 3:00 pm
We use Z&F Laser Control software to check our 5010C scanner.
Im not sure if is possible to setup the scanner manual to scan in two faces but the application inside the software do that.
We check our scanner with 10 permanent B&W targets and also against Leica TS30.
Below a report I did last week.
MedoLedo
Post by MedoLedo » Wed May 24, 2017 9:46 am
Thank you very much for the reply.
I find this very interesting. I have no experience with Z&F software. Now I tried to find a bit more info about the "Z&F System Check" but without much luck. Do you need to place targets on some predefined places or they are arbitrarily distributed? And when you do the target-based registration on the field can you select scanning of the targets in two faces?
I apologies for many questions, but this is an interesting topic.
anonimou
Post by anonimou » Wed May 24, 2017 9:21 pm
Hi again,
About your question about the targets, see below how Z&F advice.
The second question, I dont know any way to setup the scanner manual to scan in two faces and I almost sure that the scanner dont have that option.
Only when I run the "system check" but its all automatic, I dont need to do anything.
MedoLedo
Post by MedoLedo » Fri May 26, 2017 8:43 am
Ok! That is good to know.
Formula1982
Full Name: Stephen Ferrari
Post by Formula1982 » Fri May 26, 2017 9:08 am
We have a Trimble SX10. Since it combines features of a laser scanner and those in a totalstation, we can set up each position shooting onto control points by measuring rounds, ie 2 faces. Is this what you mean?
MedoLedo
Post by MedoLedo » Fri May 26, 2017 3:22 pm
Yes, that is what I mean. Thanks for the input.
Generally, every panoramic scanner, or the scanner like this one you use should be capable of doing it.
However, as far as I understood in many cases this is not supported by the instrument's software, which I find very strange...
