Small Void Scanning
Discuss Cavity Scanning here.
Honorary Member
Honorary Member
16
Has thanked: 45 times
Been thanked: 40 times
Re: Small Void Scanning
Post by Matt Young »
Because it is a generalization and does not accurately represent what a laser scanner does. In perfect and un-realistic conditions, then yes it is possible, there are no perfect conditions.
3D objects are different in size, colour, distance, temperature, shape, reflectivity. A laser scanner is a constant and will be affected by all these things.
It is better to say that 2mm is acheivable in a certain benchmark/calibration situation. Or that it is an average sum of all the errors. Given that it is an average then the accuracy for any given point could would have a lesser chance of being 2mm.
Oliver Buerkler
15
Full Name: Oliver Buerkler
Company Position Title: Director of Laser Scanning
Skype Name: oliver_buerkler
Has thanked: 38 times
Been thanked: 12 times
Post by Oliver Buerkler »
Of course you are right:
Accuracy is heavily depending on the reflectance of the scanned objects (that´s by far the largest portion of influence).
That´s why all vendors specify the accuracy under certain circumstances. Typically 10% or 90% reflectance are used.
This is mostly not to limit repsonsibility but rather to have any chance at all to give a specification. The actual results are always depending on the specific situation and can by principle not be standardized.
Best regards,
Oliver Bürkler
Oliver Bürkler
FARO Europe GmbH
Twitter: FARO_LS_PM
Return to “Cavity Scanners”
