P20-Spheres
dguise
Full Name: David Guise
Company Details: Lsc Design Inc
Company Position Title: Site Tech
P20-Spheres
Post by dguise » Wed Jan 21, 2015 1:53 pm
Has anyone used 3" or smaller sphere's for reference targets in scans. if so at what distance and what were the results. Looking at mounting on the face of a building for scans at 6 month intervals.
Has thanked: 34 times
Been thanked: 23 times
Re: P20-Spheres
Post by Matt Young » Wed Jan 21, 2015 2:56 pm
Welcome to the Forum David :D
I'm not sure if it's still the same but you used to be able to set the sphere size in Cyclone. How that applies on the scanner itself... I'm not sure. I used to use different sized spheres back in the days of the Cyrax 2500 and HDS3000.
cpw006
Full Name: Chris Widmer
Company Details: LAS
Has thanked: 3 times
Re: P20-Spheres
Post by cpw006 » Wed Jan 21, 2015 3:03 pm
Matt Young wrote:Welcome to the Forum David :D
Under Edit Preferences and the Scan tab there is a setting to set the size of the Sphere Target Diameter. But like you said, not sure how this works with the scanner. Worst case you could do a targeted scan on the sphere, making sure that you scan dense enough to then manually place the sphere target under Create Object, fit to cloud, sphere target with the preferences set to the size sphere you are using.
Re: P20-Spheres
Post by Matt Young » Wed Jan 21, 2015 3:38 pm
Thinking back through the mists of time... I think I actually did have to manually fit a target to each sphere. It's all coming back to me.
As for doing it directly on the scanner, maybe not...
tbwester
Full Name: Thad Wester
Company Details: WeWork
Re: P20-Spheres
Post by tbwester » Wed Jan 21, 2015 3:43 pm
I don't see why it wouldn't work. I would scan them at high res and add spheres in later.
With them being so small, I wouldn't scan them from too far away. Keep them to within 45-60 feet or so probably.
Oxbow
Full Name: Eric Bergholz
Company Position Title: CEO
Skype Name: eboxbow
Re: P20-Spheres
Post by Oxbow » Thu Jan 22, 2015 12:55 pm
Dear All,
we can generate small spheres (90 mm) or you use our accurate "3D precision measuring point disk"
to place the spheres on the building.
http://shop.laserscanning-europe.com/3D ... point-disk
US customer can order this stuff from Laserscanning America Team.
..Eric
