Combining FARO and Leica Scans In Scene
imcid953
Full Name: William J. Bryan
Company Details: Eye On Detail
Company Position Title: CEO
Post by imcid953 » Wed Jan 14, 2015 9:34 pm
Is there a way (other than converting them into a .PTX or .E57 file) to bring Leica scans into Scene to be combined with FARO scans?
Thank you,
Bill
William J. Bryan
"I prefer the tumult of liberty to the quiet of servitude." - Thomas Jefferson.
adriantaylor09
I have made 60-70 posts
Full Name: Adrian Taylor
Company Details: Revisia Ltd
Company Position Title: Industrial 3D Specialist
Country: New Zealand
Re: Combining FARO and Leica Scans In Scene
Post by adriantaylor09 » Wed Jan 14, 2015 10:34 pm
From the Scene 5.3 manual:
"If you already have scan files on your hard disk, then start their import either with the command File > Import or by Drag & Drop. SCENE can import scan files from different scanner manufacturers. You can import the scan files in FARO Laser Scan format, E57, Leica PTZ, PTX format or as an XYZ text file."
So Leica PTZ files, or the methods you listed.
imcid953
Post by imcid953 » Wed Jan 14, 2015 10:43 pm
Thank you. I guess it helps to read :oops: I knew Scene imported .PTX and .PTZ files, but didn't realize they are the Leica format. (The drop-down menu on the import window doesn't list the company associated with the file types.)
Bill
William J. Bryan
adriantaylor09
Post by adriantaylor09 » Wed Jan 14, 2015 10:54 pm
No worries, until now, I didn't know that .PTZ was a Leica format either.
