C10 Leica Splitting USB for Windy31 & USB Thumb drive
Wags
I have made 60-70 posts
Full Name: Wayne Wagner
Company Details: Unlimited Image Inc
Company Position Title: New Product Development
Skype Name: wags
Post by Wags » Tue Oct 07, 2014 2:33 am
Attached are pics of my latest challenge
This is my new work flow no more trying to see a small MMI in the sun and in the Heat !!!!
Morky
Full Name: Paul Moorcroft
Company Details: Derbyshire Constabulary
Country: England
Re: C10 Leica Splitting USB for Windy31 & USB Thumb drive
Post by Morky » Tue Oct 07, 2014 8:20 am
What a good idea! I like the fact that you can plug both the Windy31 & a USB memory stick in at the same time. The fact that you can watch a scan finish then set it transfering to the memory stick all from the ipad is great.
I can see a purchase of a hub coming on, however from this time of the year onwards it will be to keep warm in the car while the scanner does its stuff.
Great to see, well done! ;)
Regards
Paul.
"The true sign of intelligence is not knowledge but imagination." - Albert Einstein
Wags
Skype Name: wags
Post by Wags » Tue Oct 07, 2014 2:26 pm
no transfer needed just scan to the external usb thumb drive
Wags
Skype Name: wags
Use windy31 and scan to external drive at the same time
Post by Wags » Wed Oct 08, 2014 2:18 am
Don't think I explained this well enough scanning to a usb drive makes it very quick when you need your data
do not make your project on the internal drive also if you do some set up prior to the field you can really save
a lot of time
Using the windy31n to a Ipad mini is the icing on the cake
so when the wifi is connected up you scan to the external thumb drive
