Add Scanner Position using Cyclone 7.0.3 C10
andrew.grigg
Full Name: Andrew Grigg
Company Details: 40SEVEN
Company Position Title: Senior Land Surveyor
Country: England
Post by andrew.grigg » Wed Aug 20, 2014 5:05 am
Hi all,
Just done some scanning using the survey setup technique/traverse on the C10, only to find that there is no scanner position vertex in the control space.
I know that you need to add the target ID manually on earlier versions of the software, but I don't know/can't remember how to add a vertex to the scanner position so I can do this.
Can anyone help?
Thank you.
Andrej
Full Name: Andrej
Company Details: Meixner Vermessung and Freelancer
Re: Add Scanner Position using Cyclone 7.0.3 C10
Post by Andrej » Wed Aug 20, 2014 6:42 am
Hi Andrew,
Go into the Modelspace and create a Vertex at 0,0,0 and than add registration label. And if you used target heights which I would assume you need to set the target height. With ADD Registration Label the point should appear in the control space.
I hope this helps.
Andrej
Phil Marsh
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Post by Phil Marsh » Wed Aug 20, 2014 8:08 am
andrew.grigg wrote:Just done some scanning using the survey setup technique/traverse on the C10, only to find that there is no scanner position vertex in the control space.
Hi Andy,
If you go into the edit preferences on the scan tab at the very bottom you can turn this on as an option. By default its set to no I think.
This will only now work next time you import data so to save time just add them yourself like above.
Also get them to upgrade to Cyclone 8 or soon to be 9.
andrew.grigg
Country: England
Post by andrew.grigg » Wed Aug 20, 2014 10:20 am
AndreJ, Phil, thanks v.much for quick response.
I'm working on the upgrade issue...
Thanks again.
andrew.grigg
Country: England
Post by andrew.grigg » Wed Aug 20, 2014 11:17 pm
Hi Phil,
Am I missing something? Can't see the option in the Scan Preferences? Is it because 7.0.3 doesn't have the option?
See image...
Hi Andy,
