p20 nodal ninja
tbwester
Full Name: Thad Wester
Company Details: WeWork
p20 nodal ninja
Post by tbwester » Thu Jul 17, 2014 8:26 pm
Where can I find a nodal ninja extension for the p20. Is it the same as the c10?
Thanks!
bwx100
Full Name: Bill Wallace
Company Details: Topcon Positioning Systems
Company Position Title: Mktg Strategy Mgr for Machine Control
Re: p20 nodal ninja
Post by bwx100 » Thu Jul 17, 2014 9:46 pm
Yes, Leica C10 and Leica P20 have the same offset from Tribrach to focal point.
You can find the parts here http://shop.nodalninja.com/search.php?s ... on&x=0&y=0
tbwester
Re: p20 nodal ninja
Post by tbwester » Thu Jul 17, 2014 11:20 pm
Thanks Bill!
pburrows145
Full Name: Paul Burrows
Has thanked: 10 times
Been thanked: 8 times
Re: p20 nodal ninja
Post by pburrows145 » Fri Jul 18, 2014 9:43 am
Anyone hear anything more on the motorised version they were working on?
christopherbyrne18
Full Name: Christopher Byrne
Company Details: Rio Tinto Iron Ore
Company Position Title: Specialist Surveyor - Mine Engineering
Re: p20 nodal ninja
Post by christopherbyrne18 » Fri Jul 18, 2014 11:53 am
No,
But have you seen the auto RGB mapping app these guys have written?
http://www.nctechimaging.com/iSTAR_applications.php
Chris
pburrows145
Re: p20 nodal ninja
Post by pburrows145 » Fri Jul 18, 2014 1:04 pm
Yes, first hand.
I cannot comment here.
Steven Ramsey might discuss via PM.
Scan-Ninja
Full Name: Fabien
Company Details: Amec Foster Wheeler
Company Position Title: Geomatics Project Manager
Re: p20 nodal ninja
Post by Scan-Ninja » Sat Jul 19, 2014 12:44 pm
tbwester wrote:Where can I find a nodal ninja extension for the p20. Is it the same as the c10?
Thanks!
What's the extension for?
tbwester
Re: p20 nodal ninja
Post by tbwester » Sat Jul 19, 2014 3:40 pm
Thanks!
For the nodal ninja. :)
Mikolajczyk
Full Name: Marcin Mikolajczyk
Company Details: MM Survey ApS
Company Position Title: Technical
Country: Denmark
Re: p20 nodal ninja
Post by Mikolajczyk » Sat Jul 19, 2014 8:29 pm
is there an extention for faro focus?
Marcin
bwx100
Re: p20 nodal ninja
Post by bwx100 » Sat Jul 19, 2014 8:42 pm
Mikolajczyk wrote:is there an extention for faro focus?
Marcin
Not my area of expertise but I wouldn't think so.
All of the stuff we designed and that Seeco manufactures was based on the offset from the tribrach. I'm not sure if the Faro sit on a tribrach or just a camera tripod setup.
I think you could use the external camera manual and there would be enough info that is you can figure out the offset from the base to the focal center of the Faro you could maybe use on of the P20 extensions and change the configuration on the nodal ninja. Alternatively, when people first started setting up these brackets they were making the extension out of wood using blind nuts so it could screw into the tribrach and bracket.
I am curious why you want to do this. If you are going to Cyclone, you could use the Faro internal images via e57 if they configured their export correctly.
