Half Scan with RGB, Half with Grey Intensity
andrew.grigg
Full Name: Andrew Grigg
Company Details: 40SEVEN
Company Position Title: Senior Land Surveyor
Country: England
Post by andrew.grigg » Sat Aug 31, 2013 2:24 pm
More questions from me, sorry.
I had a project scanned with images.
I then scanned a dark basement with no images, which was to be merged into the previous project.
I have registered both projects together and would like to export a PTS.
However, I would like the scans with images to be exported with RGB values, but the scans with no images to be exported with Grey Intensity (instead of the default yellow).
I cannot work out how to change specific scans to a grey intensity without affecting the rest of the scans.
The scans are not unified. I've tried clicking on the scans in the ModelSpace and editing the Colour/Material, which doesn't seem to do anything. When I click Global Texture Map, it should colorises the scans randomly.
Is there an easy way to do this, or is there even a way to do it?
Thanks as always.
Andy
Phil Marsh
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Re: Half Scan with RGB, Half with Grey Intensity
Post by Phil Marsh » Sat Aug 31, 2013 8:47 pm
Yes you can do it but it takes time to do - how many scans are we talking ?
andrew.grigg
Country: England
Post by andrew.grigg » Sun Sep 01, 2013 9:03 am
Phil Marsh wrote:Yes you can do it but it takes time to do - how many scans are we talking ?
Hi Phil,
About 10 scans.
arie
Full Name: Arie Kai-Browne
Company Details: University of Applied Sciences Berlin
Company Position Title: Scientific staff member
Skype Name: aaaarie
Post by arie » Sun Sep 01, 2013 5:53 pm
one possible solution (which I have not tried though!) could be the free software cloudcompare. In the newest version it can convert RGB values to scalar fields.
After that you could then filter the pointcloud based on the RGB value of that specific yellow, cut the yellow points from the pointcloud, recolor those points and merge back to the entire pointcloud.
Cheers.
Phill
Full Name: Phillip Nixon
Company Details: SKM
Post by Phill » Mon Sep 02, 2013 11:57 am
Check this post, you could apply texture maps from bw truviews. Shouldnt take too long on 10 scans
http://www.laserscanningforum.com/forum ... =46&t=6063
Phill
