Blk360 or Faro S120
gsisman
Full Name: Steve Long
Skype Name: gsisman1
Has thanked: 125 times
Been thanked: 30 times
Re: Blk360 or Faro S120
Post by gsisman »
Scott wrote:
Thu Jun 06, 2019 8:12 pm
JohnBunnFARO wrote:
Thu Jun 06, 2019 10:05 am
The FARO S120 was built in 2009, and we are running out of parts for it, because it is 2 generations ago for our scanning line. If you are looking to purchase a scanner in this price range, I would recommend the M70. This is part of our latest line of scanners and is in that same price range.
Make new replacement parts or make available good parts from scrapped units! ;) Is there a worldwide database for working parts?
:D
The "Big Boys" should partner with a small machine house if you don't want to do it yourself
Umm, that would go against the mantra of planned Obsolescence.
The previous "Built to last a lifetime" mantra (i.e. (Craftsman, Maytag, etc)....is dead
Thus the OEM market.
bdawood
Full Name: Bashar Dawood
Country: Calgary Canada
Has thanked: 4 times
Been thanked: 8 times
Post by bdawood »
Maybe that is why we are having tons of garbage on this planet, if we do something that could last for ever then this planet will be in a good shape. It looks that the only thing that will last for ever on this planet is the piles and pales of garbage. We need a planet just for that.
Scott
Full Name: Scott Page
Has thanked: 44 times
Been thanked: 16 times
Post by Scott »
gsisman wrote:
Fri Jun 07, 2019 3:19 pm
:D
Speaking of 'Maytags' -recently, I had to locate a timer for a Maytag W/D, after being told by the manufacture that the part was "no long made or worth the bother -just buy a new machine" (~$2000). The W/D was old, but clean and reliable, so I spent ~30min and located a 'new' factory timer (online) for ~$350. Once slapped back into the washer, I was back in business, saving much trouble and money. The W/D cost a lot less than my reliable FARO scanner, so we should push back on the 'Church of perpetual obsolescence' mentality that separates fools from their money. Quality goods should be supported -my 2 cents!
JonMag
Full Name: Jonathan Magal
Company Details: GeoMJ
Company Position Title: Géomètre
Country: Belgique
Post by JonMag »
Thanks for all your reply. I come back to the topic.
I'm afraid of the problems with the Faro S120 (https://www.laserscanningforum.com/foru ... 49&t=14798). The first sentence...
Is this Faro S120 less reliable than other unit ? I mean the risk of breakdown is high ? Or not more than other unit ?
landmeterbeuckx
Full Name: Lieven Beuckx
Has thanked: 37 times
Been thanked: 76 times
Post by landmeterbeuckx »
i have a trimble tx5 which is a focus s120 oem. i've had it for 6 years without any problems.
i believe it's like a car, sometimes yiu're just out of luck
LSBbvba
Tel : +32477753126
www.lsbbvba.be
Jamesrye
Full Name: James Rye
Been thanked: 11 times
Post by Jamesrye »
I know it's big and heavy, but I'd get a second hand C10 or if you can afford it a P-series scanner. The data will be levelled, you can still cloud register if you want to, but you can also use targets if you need to prove your accuracy and work to highest precision. And you can traverse with it if you want. It's a proper survey instrutment. The other scanners aren't. You might be a little longer in the field, but will have less headaches in the office.
I'd also pick up an iSTAR camera.
Has thanked: 45 times
Been thanked: 34 times
Post by Matt Young »
bdawood wrote:
Fri Jun 07, 2019 6:28 pm
I agree. We are just covering this planet with shit. And we are all lying to ourselves about it.
DoctaSayas
Full Name: Caleb Sayers
Company Details: VIP AA
Company Position Title: Architectural Designer
Country: US
Has thanked: 3 times
Post by DoctaSayas »
JonMag wrote:
Thu Jun 06, 2019 9:19 am
Thank you for the reply.
I've read somewhere that the Faro S120 have frequent hardware problems and that the repair is very expensive.
Do you heve some informations about that?
Thanks again.
The Faro scanner may have it's problems, but the BLK isn't fixable(can't even be calibrated to my knowledge) AT ALL.
I still think the biggest problem with the BLK is data transfer. The BLK is wifi only. The Faro is a simple memory card. Having experience with wifi transfers repeatedly failing on a deadline is not something I'd wish on anybody.
gnuiorc_mda
Full Name: Giovanni Scocchera
Company Details: Meridian Design Associates
Has thanked: 24 times
Post by gnuiorc_mda »
DoctaSayas wrote:
Thu Jun 20, 2019 1:57 pm
...the BLK isn't fixable(can't even be calibrated to my knowledge) AT ALL...
Not to my knowledge.
A friend of mine had his own fix and calibrated.
Gio
jcoco3
Full Name: Jonathan Coco
Has thanked: 27 times
Been thanked: 57 times
Post by jcoco3 »
Well this thread got interesting quick :like:
I like the reuse/renew theme going on throughout this thread. I just spent a year of nights and weekends rebuilding a 1978 International Harvester 484 Tractor that was ready to be hauled to the dump when I got it. It now looks and runs like the day it was manufactured and I am really proud of the accomplishment. While I thoroughly enjoyed the journey of its restoration, I wonder if bringing an older scanners back from the dead or keeping one going forever is the best thing to do or advise to someone new to the industry? My farming hobby needs are very small and this tractor that cost me a total of $2700 in parts (and my free time) will do the job, but if the job in this case is to be a functional and profitable part of this industry then I find it difficult to recommend purchasing an old scanner that will soon have no support/parts. If it does have a failure that you cannot repair then you might be out of business in an instant.
Let's go deeper...We now own 4 Faro scanners: 120s, X330, and two 350s. While my team uses a very large variety of other tools these 4 scanners remain "core" to our work. We still use the 120 as much as the rest and sometimes that is everyday. It is being used right now as I type this post! While I cannot attest to the reliability or usefulness of the BLK 360, I can say that the 120 is still very much our workhorse. It has proven to be an amazing machine and even with the few problems we have had along the way it ended up being tougher than we ever expected. It has been in some of the most extreme environments imaginable. There are so many scans on it I keep thinking the mirror is going to fly off at any point, but it doesn't care, it just keeps going much like the million-mile Toyota Tundra(s). In the course of 8 years of service "it went down," and was sent in for repair about 3 or 4 times. Its record is not flawless, but for how much this thing has been used I feel like it has an amazing track record of reliability. If you read between the lines you will find that record was only made possible because the device was under warranty and was repaired/calibrated so it could live on. We paid, and still pay dearly for that warranty, but I feel like it is an unavoidable cost of business if you cannot tolerate the time it takes to repair or replace.
I think maybe we should be asking the OP Jonathan Magal to describe his intended use? If you plan on playing the weekend warrior or feel like you might use a scanner only a few times a year to support your "real job" then I might would consider the use of an old scanner knowing that the day it craps out you can just retire it on the shelf, buy another one for(cheap) parts, or tinker with them until you get one running. If you plan on using it frequently or like many of us, all the time, then I seriously think consideration of an adequate support/warranty system is almost imperative so you can keep you business alive...basically what John Bunn said, don't purchase either. Instead buy and M70 so they can help you keep it living longer.
Because I can't help myself, I will reinforce my point by broadly asking if any of us have older equipment currently lying on the shelf unused because either it is broken and too difficult to repair, or too antiquated to be practical for your business needs today? I find myself saying, "yes we do," and also saddened by the fact that we cannot find a way to reuse them even in a depreciated manner. When I first came to my current company I dusted off an old Topcon GTS 223 our surveyors considered "a boat anchor", had it calibrated and taught myself how to use it in a limited fashion without a data collector. Even got some extra batteries for it off ebay so we could use it on the occasional project. It is like the old tractor in that it feels good to make use of it again, but when it comes down to work that is anything beyond a few check shots on a small scan project where more survey control is needed it goes back to warming the bench so that the latest high tech and most practical equipment in terms of production can be used by our surveyors. Perhaps it just doesn't pay to use the older less productive equipment on the larger more complicated projects? Considering the age of our 120s and also the aging X330, we are currently faced with the decision to sell or trade them in for new units we know we need. The business decision has already been made to upgrade, but there is enough odd sentimental value in both of them that it has made the process difficult at best and I have stalled a bit. I honestly would prefer to see them live on somehow; even giving some consideration to keeping them knowing the consequences if and when they entirely stop working as it might be better than trading them in so they can sit in a warehouse and rot forever or worse be melted down as scrap :o
To make sure everyone is good and exhausted after reading and thoroughly confused about how I stand on this topic I will tell one more story. A friend of mine who is a member of this forum still uses an old Leica Scan Station! His use is limited as the scan projects only come along every so often. I get calls from him every once in a while to help with certain logistical and software related things, but instead of telling him he is wasting his time using that old scanner we have diligently worked together to find ways to make it usable and relevant even today. We laugh about the whole thing, knowing that it is all kind of ridiculous, but we simply cannot help ourselves when both the equipment and its use for the simpler projects still "works." Still making money and helping people out with a relic that deserves to be in a museum...I don't know why, but I have come to consider his effort almost heroic while also being hilarious.
Last thoughts, I swear. This thread is underlined by more complicated matters of consumerism vs. reuse/renew, and even perhaps planned obsolescence vs. right to repair issues. For some of us there is also a subtle nostalgic element that makes me reflect on what would posses somebody like Jay Leno to collect all those old cars. I respect the need for the manufactures to make money as a part of their business, even on calibration and repairs and of course new products, but please let it be known that even though a piece equipment gets old and by your judgement perhaps useless, there is a strong desire to continue using them somehow. If you can somehow support or facilitate this bizarre need to keep them going without damaging your future sales and business growth then many of us would be grateful. I hope that the people that built all the devices I mentioned reads this and gets a chuckle about how long lived their products have been, while realizing the ramifications of their own success. It would seem like you are faced with the dilemma of designing and building devices that might last forever while the survival of your company may demand future sales that could be negatively impacted by the extended use of your existing products. Conversely, Some might say that long life is your best marketing tool for those future sales. I really don't know how to balance that equation or even if it can be, because insatiable human desire is involved.
If after reading this you are not confused and you "get it," then please enlighten me. I wrote this mess, and I am still a bit confused. Surely these product life cycle issues have already been studied, and written about in-depth in many other industries?
Jonathan Magal, I have no idea if this was helpful to you, but I honestly hope it was not a waste of your time :)
