P40 failing to boot
danielgadowski
Full Name: Daniel Gadowski
P40 failing to boot
Post by danielgadowski »
Hi guys, we have a job that required the P40 being controlled remotely. We have tried to follow official guidance by using an android device. We have turned on the Wi-Fi on the P40, but we could not see the network on the phone. Decision was made to re-boot the scanner. Since then it is crashing at the boot and hangs on the white Leica screen.
I can get into the Pxx config menu and I was able to export the logs. I'm curious if pressing the Delete User Config button could make a difference here?
Has anyone came across something like this?
I have tried to get through to the Leica Support, but you just bounce off a voicemail. I have left the message, but now its a wait...
steves01x
Full Name: Steve Smith
Company Details: Scanning
Country: Scotland
Has thanked: 16 times
Been thanked: 17 times
Re: P40 failing to boot
Post by steves01x »
No help with the booting but i have not had the remote work for over a year - since then, Nexus 6P, Pixel 2, Samsung S8, Samsung Note none will work as per the guide.
Is the live chat for HDS support not live anymore?
elsonj
Full Name: James Elson
Company Details: SCCS
Company Position Title: HDS Support
Been thanked: 6 times
Post by elsonj »
Hi Dan,
The WLAN sounds like its failed and hanging on reboot. ( Had a similar issue before)
An engineer should be able to connect remotely and switch off the WLAN.
Might need to looked at on next calibration.
Email me and i can look to move this issue along.
danielgadowski
James,
as you mentioned, it was a faulty WiFi card.
Guys from Switzerland got in remotely and turned it off so we can use it till the next calibration.
Dan
