Underwater Laser Scanning
Discuss all Underwater Scanning related issues here.
Formula1982
Full Name: Stephen Ferrari
Re: Underwater Laser Scanning
Post by Formula1982 » Wed Mar 29, 2017 11:20 am
tomcard wrote:Hi,
Very interesting stuff, we've done a lot of underwater scanning sonar but not laser yet. Is there any issue with water clarity? I would imagine that reasonable visibility is required. Also, do you use scanning sonar to provide the overall location of items, as per the last image?
We locate our scans typically the same as a terrestrial job - a choice between or combination of black and white checkerboard targets, sphere targets and cloud-to-cloud registration. To geo locate scans, or to locate them over slightly longer distances then yes solutions such as sonar LBL (like in the last image) would be used.
Yes water clarity has to be considered. However unless it's like gravy, typically subsea laser scanning works fine and clarity is not a limiting issue. We use different models of equipment for different conditions (including water depth, clarity, deployment method, total area to be scanned). Just like terrestrial laser scanning with regard to equipment choice its 'horses for courses', and again like any other surveying, having the right equipment is only 25% of the battle, you need to have experience and understand what you should and should not do!
savante
Full Name: Dr. Grant Thomson
Company Details: Savante Offshore Services
Post by savante » Wed Apr 05, 2017 4:52 pm
This is an example of some demonstration work we did using our Certus subsea laser scanner; designed specifically for subsea divers - looking at weldment measurements.
It is full colour.
youtu.be/
MinnaK_VRT
Full Name: Minna Keinänen
Company Details: VRT Finland Ltd
Company Position Title: Marketing Communications Specialist
Country: Finland
Post by MinnaK_VRT » Thu Nov 08, 2018 8:05 am
Great, a topic for us!
Our company specializes in underwater surveys. But, like some have already said, we don't use laser for that and probably have never used. This topic is a bit old by now, but I wonder what the situation is now? Is underwater laser scanning a thing, or is it still confined to the areas where the water is crystal clear?
VRT uses only multibeam sonar under the water, because with laser the data quality would be much lower. All the trifles and fluff in the water would give us a veeery smudgy image. We do scans in Europe and Nordics, and here the waters tend to be so muddy there's no point going in the water with the laser, when sonar gives us such detailed data. Though laser is used in almost every site for the structures above the surface.
Making the invisible visible.
VRT Finland Ltd.
Return to “Underwater Scanning”
