InfiPoints V4.1 now Released, Duct modeling and Oculus Rift Support
Discuss Elysium here.
TommyMaddox
Full Name: Tommy R Maddox III
Company Position Title: Sales Engineer- AEC Tech Specialist
Post by TommyMaddox » Mon Feb 12, 2018 9:46 pm
HAMAMATSU, Japan—Jan. 31, 2018— http://www.elysium-global.com/newsarchi ... 1-1000.php
Elysium, a global leading provider of point cloud solutions, announces a version-up release, InfiPoints Ver.4.1, addressing the two key factors to escalate the utilization of 3D scanned point cloud data in engineering fields. Interoperability with scanners as well as software solutions aid in engineering processes, specifically in building and facility maintenance and renovation work. The advanced outputs work to enrich communication among related people.
Release Highlights
An intensive enhancement on modeling capability to allow modeling duct elements in InfiPoints.
A new capability to collaborate with HMD (head mounted display), Oculus Rift.
View the separate press release below:
http://www.elysium-global.com/newsarchi ... 2-1200.php
InfiPoints is designed to enhance your seamless point cloud utilization in engineering. Key features include high performance viewing of laser scanned point cloud data without a limit on the data size, automatic noise removal, virtual simulation using point cloud, polygon, CAD models, and more. One of its differentiators is the capability to auto-recognize the feature shapes (planes and cylinders) in point cloud data, which allows easy and efficient modeling based on extracted planes and cylinders.
In Ver.4.1, a toolset for duct modeling has been added to complete the modeling functionalities. Duct systems often run avoiding the building structure, lighting, etc., so that, compared to piping systems and the steel structure, duct parts are often customized in size and shape to fit in the actual environment. This means that modeling a duct system is not as simple as inserting pre-defined standard parts. In other words, modeling based on the captured reality is an effective and efficient method for such. In InfiPoints, users can quickly model duct parts–create straight ducts by selecting extracted planes, connect selected straight ducts by inserting S-curves, duct elbows or hoppers, and replace created parts by standard parts. Users can also easily adjust the size and location, e.g., reduce the section size for the insulation thickness.
Those modeled elements can then be exported in multiple CAD formats including IFC format, an ISO standard neutral format invented to facilitate interoperability in the architecture, engineering and construction (AEC) industry. IFC format is as well a commonly used collaboration format in Building Information Modeling (BIM) based projects. In IFC export, parametric information such as length and diameters is maintained, which allows further editing in equipment and architecture CAD systems.
Ver.4.1 also includes the following capabilities to remove obstacles that stop seamless utilization of 3D scanned data in combination with other related data:
An enhancement on virtual simulation to enable collision detection between point cloud and 3D drawing file (*.dwg) as well as other CAD and polygon formats.
Added support for ASTM E57, a neutral format for point cloud data.
Lots of great features and improvements in Version 4.1 Official. PM me or reach out through our website if you have any questions or would like to have an evaluation or case study done for your applications.
http://bcengineeringanddesign.com/
Learn more about InfiPoints here:
https://elysiuminc.com/products/infipoints/
Return to “Elysium”
