GEOSLAM Announce New ZEB HORIZON Scanner
Discuss all GeoSlam related products here
Has thanked: 89 times
Been thanked: 36 times
Post by Jason Warren »
Meet the latest member of the GeoSLAM family, the ZEB-HORIZON 3D mobile scanner.
With a range of 100m, the ZEB-HORIZON is great for outdoor use, yet its lightweight and compact design also makes it perfect for indoor surveys.
ZEB HORIZON is your tool to capture, process and understand the world around you.
youtu.be/gWmq2EKZj0Q
Lightweight and rugged, ZEB-HORIZON is simple to use, fast to capture and easy to process, so you have the most accurate information you need to make the most important decisions.
With powerful SLAM technology at its heart, the ZEB-HORIZON can even be used in remote areas with poor GPS - such as underground or in forest environments.
Go further than ever before with ZEB-HORIZON's range of mounting options, including UAV compatibility.
Unlimited Solutions
With a collection rate of 300,000 points per second, and an accuracy* of 1-3cm, the ZEB-HORIZON is suitable for a vast array of applications, including:
  • 2D floor plan generation
  • 3D volumetric calculations
  • Measured Building Surveys
  • Scan-to-BIM
  • Object Identification
Further information at:
https://geoslam.com/zeb-horizon/?utm_so ... i=66709491
Jamesrye
Full Name: James Rye
Been thanked: 11 times
Re: GEOSLAM Announce New ZEB HORIZON Scanner
Post by Jamesrye »
Interesting. Having used the RT solution, the GeoSLAM Hub program needs improvement, so I'm interested to try that.
The promo video says the device captures "intensity", but none of the images show that, they are all coloured by normal value / height.
The data sheet is also interesting.
Under colourised point cloud, the spec sheet says "improved". Interesting comment that, considering I couldn't colourise my data at all using the RT solution.
There is also a tick by "referenced imagery", which I am interested to know more about. Does this mean that ortho-images can be produced? Or does this mean that you click a point in the cloud and it references to the relevant frame of video?
yankoch
Full Name: Yan Koch
Company Details: TagLabs
Has thanked: 10 times
Been thanked: 38 times
Post by yankoch »
Interesting indeed, but it looks like a fishing reel!
kpob46
Full Name: Kyle OBrien
Company Details: Nutrien
Company Position Title: Mine Technologist
Post by kpob46 »
Looks like they are using a Velodyne puck now instead of the Hokuyo sensor. The Velodyne puck should provide intensity data.
Ioannis
Full Name: Ioannis Papas
Company Position Title: CEO
Country: EU
Skype Name: -
Has thanked: 15 times
Been thanked: 13 times
Post by Ioannis »
But the data still it will drift..
smacl
Full Name: Shane MacLaughlin
Has thanked: 91 times
Been thanked: 106 times
Post by smacl »
kpob46 wrote:
Tue Oct 16, 2018 8:57 pm
Nice. Also a massive jump in data density at 300,000 points per second where the Revo was 40,000 points per second. Anyone know if there's any sample data available yet?
tbwester
Full Name: Thad Wester
Post by tbwester »
the puck should give longer range, but i believe it is a bit more noisy compared to the Hokuyo. Is that right?
Brett
Full Name: Brett D
Company Details: Omega Geomatics
Country: England
Post by Brett »
I saw this at Intergeo. The sample data set that was on show was a simple walk around their offices. It looked quite impressive! Sven toggled between the various display settings and i saw the intensity values settings. Looks like a good bit of kit!
VXGrid
Full Name: Martin Graner
Has thanked: 12 times
Been thanked: 17 times
Post by VXGrid »
Ioannis wrote:
Tue Oct 16, 2018 10:27 pm
Since you have more range and more points/m² the feature detection will be easier for SLAM and therefore I guess the drift could be lower.
Haven't checked the specs yet so I don#t know about the accuracy.
mark.reid
Full Name: Mark Reid
Company Details: GeoSLAM
Company Position Title: Chief Operating Officer
Skype Name: mark.reid21
Post by mark.reid »
Hello everyone, thanks for showing interest in our new ZEB-HORIZON solution.
To answer some of your questions;
- ZEB HORIZON has been launched with a new version of GeoSLAM Hub that is fully windows based hence no longer a need to install the virtual machine
- Yes we now supply intensity with the ZEB-HORIZON, an example with road markings taken from the new viewer is below
- We also have improved ZEB-CAM synchronisation for the HORIZON which when combined with having more points enables improved colourisation as below
- A new pointcloud smoother option has also been implemented to further enhance the data
- With ZEB-HORIZON we are seeing our strongest and most robust SLAM to date both indoor, outdoors, and within challenging environments. As mentioned this is helped by having the longer range and increased point density for feature identification
Hope this helps, the product is immediately available and we have had some great feedback this week at Intergeo. If you need more info you call also contact geoslam at [email protected]
Return to “GeoSLAM”
