GEOSLAM Announce New ZEB HORIZON Scanner
Discuss all GeoSlam related products here
SCCS RTC
Full Name: Phil Marsh
Skype Name: Phil.H.Marsh
Been thanked: 11 times
Re: GEOSLAM Announce New ZEB HORIZON Scanner
Post by SCCS RTC »
Jamesrye wrote:
Tue Oct 23, 2018 8:42 am
I'm interested in hiring this kit - any news about when this will be an option?
We will have them from next week ;) (In the UK anyway)
M: 07540 201383
E: [email protected]
W: www.sccsurvey.co.uk
Has thanked: 59 times
Been thanked: 59 times
ScottKarlins wrote:
Thu Nov 22, 2018 6:02 pm
Here you go!
https://geoslam.com/zeb-horizon-data-giveaway
Thanks Scott, just had a look at this data now in SCC. There are two models, a road bridge and UAV mounted aerial scan. Looking at the bridge, at first glance the data seems very noisy with ~100mm noise on the bridge struts. The bridge deck, which would be much closer to the scan head, is way better and shows ~35mm noise. There could well be movement on the bridge, so maybe not an ideal structure to use for testing. It would also be useful to know whether the scan was done hand-held or with a backpack. Having processed a number of Pegasus backback jobs in recent months, the Pegasus data seems less noisy, which could in some part be due to being on a backpack rather than hand-held. Increased data density does provide greater scope for automated post-processed noise elimination, which is a big advantage over the ZEB-Revo. I'd be interested in seeing some internal building or cave scans where this unit could potentially be very strong.
UAV data is really clean with a 200mm thick slice showing ~35mm of noise, which leads me to suspect that the IMU and SLAM mechanisms benefit hugely from a steady platform and constant velocity.
sheartab
I have made 100> posts
Full Name: Sheartab
Company Details: Arch Eng Design Firm
Country: US
Has thanked: 7 times
Been thanked: 5 times
Post by sheartab »
Following up with the Hub users- Does Hub provide a means to reduce the noise that is generated from the Horizon?
VXGrid
Forum Supporter
Forum Supporter
Full Name: Martin Graner
Has thanked: 6 times
Been thanked: 13 times
Post by VXGrid »
sheartab wrote:
Thu Aug 29, 2019 4:50 pm
As far as I know there is an option to reduce the noise in planes (like walls, floor, etc).
This will of course not work for any other shapes which are not flat.
Return to “GeoSLAM”
