Just wondering if its possible to ask ImAlign to select and delete all - line scanner feathering at the edges - I spend a lot of time clean up this type of date prior to meshing.
As per these images
ImAlign - Line Scanner Data
- NOVAMECH
- Full Name: Nick Bush
- Company Details: NOVAMECH
- Country: New Zealand
- Skype Name: novamech5
- Has thanked: 9 times
- Been thanked: 9 times
- Full Name: Alexandra Pickel
- Company Details: Lidar Guys
- Company Position Title: employee
Re: ImAlign - Line Scanner Data
I don't think Align can do that, but if you export as .ply, you can then use Survey to select the polygonal model boundaries and delete from there.
Lexi
Lexi
- Full Name: DAN BOX
- Company Details: 3D Scanners UK Ltd
- Company Position Title: PROJECT ENGINEER
Hello there,
This might be a little late but you could try the select best data tool with in Align
- nickherath
- I have made 60-70 posts
- Full Name: Nick Herath
- Company Details: Veris
Thats not normal behaviour from an LLP.
Check your max angle settings in your line scan options. Defaults should be 75 degrees. If you have opened it up wider than this (say 89degrees) that may be responsible for the flaring.
If not, how long since the LLP has been factory calibrated? Have you tried a re-calibration of the scanner in RDS?
- NOVAMECH
Thanks Nick , yes somehow we have our setting set at 85 degree as default, Reducing this back to 75 helps. Also, yes we will try to calibrate using our manual. You may like to check out NOVAMECH on FACEBOOK. And see our new NDI Optotrak Pro CMM system working with PolyWorks v12. Like the page please, we need more "Likes"
