Export ReCap
Discuss Z+F Laser Control here.
AdamLS
Full Name: Adam Westfall
Company Details: PVE
Company Position Title: Mid-Atlantic Regional Manager
Export ReCap
Post by AdamLS » Wed Mar 06, 2019 8:47 pm
I've been working on exporting an LC project to a ReCap project file for the past seven hours. For the past hour the progress bar has shown it is finished but it has continued to add another 5GB or so into the support folder. Wondering if there's a way to know when this will actually be finished?
gabrio
I have made 100> posts
Full Name: Gabrio Rossi
Re: Export ReCap
Post by gabrio » Wed Mar 06, 2019 10:39 pm
how many scans? how many MB each scan file? which kind of hard disk to read and write: Ssd? pci express m2?
i hope it will be ended when you read this post ;-)
arch. Gabrio Rossi, MRICS
g.rossi@intellegere.net
24121 Bergamo - Italy
+39.035.601.1492
AdamLS
Re: Export ReCap
Post by AdamLS » Thu Mar 07, 2019 12:31 am
Yes finally, thanks. It said "finished" at 54 GB, then ran another two hours and totalled 61 GB.
gabrio
Re: Export ReCap
Post by gabrio » Thu Mar 07, 2019 6:14 am
so now you have a ReCap project built on structured point cloud (zfs file) with bubble view.
if you only need to use it to work in autodesk software you may want to have a lighter recap project. in this case better to use unstructured point cloud, lose bubble view but much smaller recap folder.
m2c
+39.035.601.1492
AdamLS
Re: Export ReCap
Post by AdamLS » Sat Mar 09, 2019 2:02 pm
I don't see an option to export any different version of ReCap? I've tried e57 and las, but both export a file for each scan. The only unstructured option I see is PTS.
Edit: Nevermind, found the export unified option in ReCap. Thanks for the tip! In the past I did all of those types of edits in Cyclone, so never learned much about ReCap except import and use it in Civil3D or Revit
AdamLS
Re: Export ReCap
Post by AdamLS » Sat Mar 09, 2019 3:13 pm
m2c
Although, when I tried to export the unified/unstructured from ReCap my support folder more than doubled in size?
Return to “Z+F Laser Control”
