2.5D volume calculation
- danielgm
- Country: France
- Has thanked: 11 times
- Been thanked: 34 times
Thanks to EDF's support there's a new 2.5D volume calculation tool in preparation for the next release:
Basically it computes the volume by projecting one or two clouds in a 2D grid. It works well for stockpile volume estimation, and more generally with any cloud acquired from above. When a single cloud is used, a constant height can be set as 'ground' height.
Here's a quick documentation:
http://www.cloudcompare.org/doc/wiki/in ... generation
And here's a link to the beta version:
http://www.cloudcompare.org/release/Clo ... in_x64.zip
Feel free to test it and make some feedback!
- Country: Italy
- Has thanked: 15 times
- Been thanked: 53 times
Re: 2.5D volume calculation
Great stuff!
Thanks,
Thanks,
- Full Name: Matteo Dallagiacoma
- Company Details: Rilievo Digitale
- Company Position Title: founder
- Country: Italy
Ohh!
That would be really comfy!! otherwise I do need a lot of import export and other softwares to get the job done. Congratulation for the outstanding job as always
Regards
Matteo
www.rilievodigitale.com
Regards
Matteo
- Full Name: Tomasz Gerlich
- Company Details: OutPut Precision Ltd
- Skype Name: tomek.gerlich
- Has thanked: 5 times
- Been thanked: 7 times
nice update! <like>
Best Regards,
Tomasz Gerlich
+44 7756613300
Best Regards,
Tomasz Gerlich
+44 7756613300
- EdgarTrevizo
- I have made 80-90 posts
- Full Name: Edgar Omar Trevizo Aragon
- Company Details: GrupoITT
- Country: Mexico
Hi all.
The ground height can be up from a single cloud? to calculate the fill volume
Edgar
Edgar
- danielgm
- Country: France
Yes you can use a single cloud and define a constant height as 'reference' (0 by default).
- EdgarTrevizo
- Country: Mexico
- Full Name: Tertius JB Kruger
- Company Details: Vinitra Consulting
- Country: South Africa
Daniel, fellow forum members, I need some help in understanding this process. I'm new to volume calculations with 3D scans
This is my cloud. It is an already clipped excavation from a sloped site. The clip was executed all along the ridge. When I run the calculate function using only this cloud, this is the result. What I'm after: what exactly is this function calculating on this cloud. Is it creating a surface all along the highest points on the outer edge to create a 'ceiling' so that I'm ending up with the accurate amount of excavated soil?
Here is the grid exported a cloud. Any help on this matter
- smacl
- Has thanked: 627 times
- Been thanked: 657 times
Not a CC user but the report suggests a regular grid of cells at a 0.1m interval are used to calculate the point cloud part of the volume. Not sure how the the base/top surface is created, in SCC we'd create a 3d polygon for this and mesh it to create this surface. In this case I see that 'Ground Before' is set to 'Constant' which suggests a fixed elevation to me which may not be what you are after.
