FLS files & RGB
Discuss all CloudCompare issues here.
Dedken
Full Name: Kenneth Bazley
FLS files & RGB
Post by Dedken »
When importing FLS files into CC, RGB doesn't appear to be supported unless I'm very much mistaken. Is this planned for future releases? Also, if one edits an FLS in CC, will the RGB in the original file be retained when exporting from CC?
Cheers.
EDIT: it appears we're sorting this through the Github channels..
3DForensics
Full Name: Eugene Liscio
Skype Name: eliscio
Been thanked: 7 times
Re: FLS files & RGB
Post by 3DForensics »
Good point. I don't normally use fls or Scene projects in CC too often (usually just the exported cloud) but it's good to know if this is a bug or by intent. What's interesting about this is if we can get color, then there is no longer the need to import a massive point cloud for decimation. I could do it by simply importing the Scene project and then calculating the spatial filtering (in theory).
Please keep up posted.
Eugene
danielgm
Company Details: CloudCompare
Re: FLS files & RGB
Post by danielgm »
Here is a little update on this subject:
  • the initial version of the FARO plugin was only importing the 'reflection' values as a scalar-field
  • we tried to import RGB values instead but no luck, we get the same grey 'reflection' colors (but as RGB components ;))
The FARO LS SDK is very simple. The only information about this in the documentation is:
With the default settings, the functions will load the scans with color information if it
is available
Even FARO Scene LT only displays grey reflection values/colors (but the pictures associated to the scan are accessible). And Ken told me that in Faro Scene you have to explicitly 'apply' the pictures to view the RGB colors.
But Recap does load the right RGB colors right away!!!
Anyone knows what's at stake? Does Recap do the 'apply pictures' job automatically? How?
[EDIT] If the images are 'applied' in Scene and the file is saved again then it can be successfully imported in CloudCompare in RGB. So that's a solution.
I still wonder how Recap does it automagically ;)
Daniel
CloudCompare admin
http://www.cloudcompare.org/
Oliver Buerkler
Full Name: Oliver Buerkler
Skype Name: oliver_buerkler
Has thanked: 10 times
Been thanked: 5 times
Re: FLS files & RGB
Post by Oliver Buerkler »
Hi Daniel.
If you need support in implementing specific functioniality with the FARO SDK, our development team will be happy to support you.
In case you do not have their contact data, please send me an email :)
Best regards,
Oliver Bürkler
Oliver Bürkler
FARO Europe GmbH & Co. KG
Twitter: FARO_LS_PM
danielgm
Re: FLS files & RGB
Post by danielgm »
Definitely!
Thanks Oliver.
Daniel
CloudCompare admin
jedfrechette
Full Name: Jed Frechette
Company Details: Lidar Guys
Has thanked: 6 times
Been thanked: 31 times
Re: FLS files & RGB
Post by jedfrechette »
It would be great if these types of development questions could get asked and answered on a StackExchange type bulletin board that the development team monitors rather than private email. I suspect a lot of people trying to work with the SDK are coming up with similar questions and only needing to answer those questions once could really improve efficiency. Not to mention, leveraging the knowledge of more experienced users of the SDK.
Oliver Buerkler
Re: FLS files & RGB
Hi Jed.
Every development partner of FARO is supported by our team.
The official documentation for the FARO API is publicly available on the internet.
Since in software development the majority of issues and problems are very specific.
In addition, both involved parties agree in keeping mutual knowledge of the IPs confidential.
Therefor I do not think a public forum would be helpful.
Best regards,
Oliver Bürkler
Oliver Bürkler
Twitter: FARO_LS_PM
jedfrechette
Re: FLS files & RGB
Oliver Buerkler wrote:Since in software development the majority of issues and problems are very specific.
Not that my experience is definitive, but I've found almost the exact opposite to be true. Almost every development issue I've ever encountered, from setting up a specific project's build environment, to design best practices, to how to call a specific function; have been things that someone else has already encountered. Judging by the success of sites like StackOverflow that doesn't seem to be a unique experience.
Oliver Buerkler wrote:Therefor I do not think a public forum would be helpful.
Ok, how about a private forum then, although if the questions are about usage of a publicly documented API I'm not sure what IP there is that needs protecting. Just to give one example Autodesk does it both ways. Their AutoCAD developer forum is private, while the analogous forum for Maya is public.
I know I can almost always get an answer to any user space question quicker here then from support, simply because the number of people who might know the answer is greater. I would be great to have the same resource available for development related questions. Crowd sourcing and all of that.
A_Axelsson
Full Name: Anders Axelsson
Company Details: AF Metrology
Country: Sweden
Re: FLS files & RGB
Post by A_Axelsson »
Still no progress on being able to import FARO files with the RGB information applied?
3DForensics
Skype Name: eliscio
Re: FLS files & RGB
I just sent in a bug report after testing...still not loading a raw scan even when you choose to load the RGB.
I also just processed and exported a single scan with color as .fls and it doesn't work either.
...speaking to Daniel G.M. tomorrow so will ask.
Eugene
Return to “CloudCompare”
