I have been trying to create normals from an imported Hovermap .laz file but not getting much success at all. Is there a way in Cloudcompare to generate normals based on a trajectory file?
I have also tried in Metashape but it creates lots of inverted normals too. There is an option in Metahsape to use a trajectory file but I don't think it supports XYZ trajectory files.
I thought about trying to create TLS sensors along the trajectory file and using them to orient/create normals in the SLAM data but I don't see any option for that (or I'm not understanding the correct process).
Has anyone done anything like this before using Hovermap or other SLAM data?
I have put these questions on both the Cloudcompare forum and emailed Metashape support directly but neither of them have responded.
Normals from trajectory file - Hovermap SLAM data
- Full Name: Chani Tough
- Company Details: ZynQ 360 Limited
- Company Position Title: Innovation Manager
- Country: United Kingdom
- Daniel Wujanz
- Full Name: Daniel Wujanz
- Company Details: technet GmbH
- Has thanked: 206 times
- Been thanked: 188 times
Re: Normals from trajectory file - Hovermap SLAM data
Dear Chani,
if you have time stamps for both the trajectory and the point cloud then you can compute quasi static scans. You can then proceed with them as usual.
Have you got this information?
We have a prototype which does exactly what you need yet for another task. If you want, I can prepare the data for you.
See https://www.youtube.com/watch?v=1NN6r6juE7I&t=1908s at 34:52 min:sec
Daniel
Daniel
Hi Daniel, thanks for the reply. The Hovermap produces an xyz trajectory file which has the following columns: time gpstime x y z pitch roll yaw rot.w rot.x rot.y rot.zDaniel Wujanz wrote: ↑Tue Nov 01, 2022 3:05 pm Dear Chani,
Daniel
The Hovermap itself stores the following point cloud attributes: Intensity, range, time, return number
(strongest & last) and ring number
I'm guessing that should be enough to match the time code of the points to the same time position in the trajectory.
- Daniel Wujanz
Nice, could you send me a chunk of that data to see if we can do something with it or is it critical data? If the latter applies, is there a demo dataset that I could use?
Daniel
Daniel
- RobM
- I have made 100> posts
- Full Name: Robin Miller
- Company Details: My own boss
- Been thanked: 14 times
I just looked at your video.
as we talked about the time stamp topic before, one thing came to my mind:
with the VLX, wouldnt it be sufficient to cut the "point sausage" ,as you called it, exactly at those points where panoramic images are taken? because there are known timestamps for the images and I`d assume with the image being present there should be an option to turn them into "pseudo structured scans". in your presentation you wrote "where static behavior can be assumed" and I am thinking, as you stop to take the image with the VLX that might be exactly what you are looking for?
Daniel
- MarkJLane
- Full Name: Mark Lane
- Company Details: Faro Technologies
- Company Position Title: ANZ Account Manager
- Has thanked: 25 times
- Been thanked: 43 times
Using Cloud Compare, you should be able to save that trajectory file into a format that Metashape will accept.Chani_ZynQ360 wrote: ↑Tue Nov 01, 2022 1:35 pm Has anyone done anything like this before using Hovermap or other SLAM data?
Alternatively, with the ZEB Horizon and Vision camera, I can export a structured E57 based on the camera interval. Using this E57 I can calculate normals based on sensor origin.
- Daniel Wujanz
Dear Robin,RobM wrote: ↑Wed Nov 30, 2022 9:03 pm I just looked at your video.
I've had many discussions with Navvis at Intergeo and the conclusion is (I cannot say more) that the system operates slightly different than others. The problem is that timestamps for single points cannot be retrieved. Hence, you cannot associate single points to image timestamps.
However, we're in close exchange with Navvis to find a solution.
All the best
Daniel
