I have some scan data and when i tried to register them with Fine registration (ICP) the RMS error is about 0.012 (final overlap %1 and random sampling imit is 300000) but i need more precise registration. I applied fine registration again with registered data and the RMS error decrease to 0.0072 is that right way for precising the registration.
Briefly;
DATA1 and DATA2 registered with ICP then i applied ICP again between DATA1 and DATA2.registered. And RMS error decreases significantly is this process correct for a high precise registration
Thank you..
About ICP registration
- Full Name: Mehmet Volkan Ozdogan
- Company Details: Dokuz Eylul University
- Company Position Title: Research Assistant
- Country: Turkey
- danielgm
- Full Name: Daniel Girardeau-Montaut
- Company Details: CloudCompare
- Company Position Title: Administrator
- Country: France
- Has thanked: 11 times
- Been thanked: 34 times
Re: About ICP registration
1% percent overlap seems very low! Not sure the result is reliable...
Otherwise pay attention that the RMS is only computed on the points selected during the last iteration (points are randomly selected - up to 300000 here - but only inside the closest points defined thanks to the overlap parameter... so there might not be that much points).
Running the algorithm twice can help sometimes (in case ICP is 'stuck' in a local minima). But once again, you'd better have a reliable selection of points to avoid jumping to a wrong solution.
- stevenramsey
- Full Name: Steven Ramsey
- Company Details: 4DMax
- Skype Name: steven.ramsey
- Has thanked: 30 times
- Been thanked: 72 times
it will also depend on the scanner used. all scanners have inherent error each one is different as you can't say that a single scan has a zero error. even two scans from the same location will unlikely give you a RMS value much better than the scanners error. As Daniel says 1% is very very low for an overlap
- Country: Turkey
danielgm wrote: ↑Tue Apr 09, 2019 11:10 pm 1% percent overlap seems very low! Not sure the result is reliable...
Thank you for your answer,
What is the suggested overlap ratio for a reliabe registration (%10 ? )
And what can i do for a better registration?
Thank you
- danielgm
- Country: France
Yes, 10% is the minimum. And if you can increase that (during scanning) that's of course better. You'd better take overlapping parts of the scan that have some geometry and not too flat or smooth areas.
