batch process for subsampling in CC?
- blazaj
- Full Name: Jiri Blazek
- Country: Czech Republic
- Has thanked: 45 times
- Been thanked: 18 times
is it possible to batch process loading - subsampling - saving subsampled copy of E57 in CC?
Jiri
Jiri
- IngSayyad
- Full Name: shahzad sayyad
- Company Details: Ingenieurbuero Drecoll
- Company Position Title: Entwicklungsingenieur
- Skype Name: shah.baba_2012
- Country: Italy
- Has thanked: 15 times
- Been thanked: 53 times
Re: batch process for subsampling in CC?
Sure.
Create a batch file with the following line
You can drag and drop multiple files.
This one is doing spatial subsampling and saving as E57
Code: Select all
for %%f in (%*) DO "C:\<YOUR PATH HERE>\Cloudcompare\cloudcompare.exe" -SILENT -O %%f -C_EXPORT_FMT E57 -SS SPATIAL 0.01
- blazaj
It works perfectly, thanks again! One more thing, after subsampling I need to bake intesity values to RGB. Is there a command to do that in the batch? Sorry, the wiki page doesn't seem to work right now.
- danielgm
- Country: France
- Has thanked: 11 times
- Been thanked: 34 times
This option is not available through the command line (as no one has ever asked for it .
- blazaj
Much appreciated Daniel,
it saves quite a lot of time to batch subsampling on something like 300 scans! The reason asking for the latter was to automate converting intensity colored scans into software as ArchiCAD or Rhino 3D which can natively only work with RGB values.
Regards
Jiri
Regards
Jiri
- Country: Italy
Funny thing in those days I was considering the possibility to move a scalar field to rgb (normals) and batch process the scans. Having the options in the command line would be great.
Well... In general the command line is great!
Jiri, for Rhino check the Arena plugin..
- blazaj
Massimo,
I had a demo of the plugin and it's impressive how it handles and visualize large pointclouds in Rhino. The only drawback for me is its own file format. I like to stitch to unified e57 which I can also import almost instantely to Archicad.
Jiri
Jiri
- Country: Italy
Jiri,
Probably part of the insane performance of the plugin is related to the proprietary format. You can export also the arena cloud to neutral formats (including E57) using arena studio in unlicensed mode.
I saw a demo of rhino + arena + visualarq and it's jaw dropping.
While this is getting off topic cloud compare and its command line is a great solution to glue everything together.
I have a set of batch files for the most common tasks.
I only wouldn't use rhino with a native point cloud... It is not meant to be used with a cloud of few hundred million points.
