Need help to export file in .DP format from CC after alignment & merge
Discuss all CloudCompare issues here.
Prithvi
Full Name: Prithvisingh Chauhan
Company Details: Powersource Philippines Development Corp
Country: Philippines
Post by Prithvi »
I am new to CloudCompare and would appreciate any help on exporting aligned & merged file into .DP format.
I have tried it on v2.11 alpha as well as stable v2.10.2 (windows 64 bits) but it displays an error msg.- 'This function is not implemented yet'
Can i downgrade to any lower version? where to get that version?
I will use the output file in Recap and then in Autocad.
(I tried few another formats but the file size shoots up enormously.)
regards,
Prithvi
danielgm
Company Details: CloudCompare
Been thanked: 7 times
Re: Need help to export file in .DP format from CC after alignment & merge
Post by danielgm »
No sadly this feature has probably never been implemented!
Daniel
CloudCompare admin
http://www.cloudcompare.org/
Prithvi
Post by Prithvi »
Thanks for the response Mr. Daniel!
I saw a tutorial video from DotProduct wherein they demonstrated saving the output file in .DP format.
In the demo they seem to have used CC version 2.7.0 stereo (64bit)
(refer video link: https://youtu.be/48xILOe9d7I)
Prithvi
danielgm
Post by danielgm »
Ok sorry, you are right, that's definitely an option! :shock:
And actually there were two different issues here:
1- the DP export filter was broken in the last version (it's now fixed if you download the latest 2.11.alpha version)
2 - you need a grid structure attached to your point cloud to actually be able to export the cloud as a DP file (which means that you need a cloud imported from a FARO or PTX file)
Thanks for the feedback!
Daniel
CloudCompare admin
Return to “CloudCompare”
