How to Install Rhino plugin
Mastodont87
Full Name: Ivan Borisov
Company Details: Vertex3D
Company Position Title: LTD
Country: Russia
Skype Name: mastodont87
Post by Mastodont87 » Thu Sep 08, 2016 3:31 pm
Dear support!
I'm using Rhino 5 and have downloaded an exe file of Arena 4D from your website. But don\t understand how to instal it. After instalation of the exe files nothings changes in my Rhino interface. In the user guide nothing says about exe files but only about rhp files.
Could you please help me.
Thanks in advance.
Mark Christy
Full Name: Mark Christy
Re: How to Install Rhino plugin
Post by Mark Christy » Thu Sep 08, 2016 3:48 pm
Please follow our tutorial video here which should help you
youtu.be/
Sometimes you have to restart Rhino once everything is installed before point clouds are visible.
Also to create VPC files from e57 or LAS files you will need to download our VPC creator from our website too.
Many Thanks
Mark
Mastodont87
Country: Russia
Post by Mastodont87 » Fri Sep 09, 2016 2:55 pm
I have still some problem with it.
I use Rhino Version 5 SR2 (5.2.30328.21415, 28.03.2013) 64 bit.
From your website plugin installs in 32 bit version, more over when I manually choose rhp files it says me next thing:
Thia plug-in is designed to run in the latest Rhino 5.0 Release. Please download the latest service release.....
Does it mean that I can't work with my Rhino version?
max72
Full Name: Massimo De Marchi
Skype Name: massimo_de_marchi
Post by max72 » Fri Sep 09, 2016 3:37 pm
My current rhino version reads:
5 SR12 64-bit
(5.12.50810.13095, 10/08/2015)
Maybe you need to install some updates..
Mark Christy
Post by Mark Christy » Mon Sep 12, 2016 1:47 pm
Mastodont87 wrote:I have still some problem with it.
You need to update your Rhino version to the latest version. You will find an update option under the Help menu... Help -> Check For Updates.
Our plugin is both 32bit and 64bit compatible. Once installed it will run in either version of Rhino.
Mark
Return to “Arena4D”
