I scanned a building, using a BLK 360 and a Matterport (to capture the inside of a large crawl space). In Realworks I have registered the BLK 360 9.e57) scans together. I imported the Matterport/Matterpak data as an .xyz (ASCII)file. The Matterport pointcloud has come in really small compared to the BLK scans.
Is there a way to change the scale of an .xyz file, so it could be resized to match the size of the pointclouds in my RealWorks project?
I appreciate your help. Thank you for your time.
Need to change scale of imported .xyz file in RealWorks?
- Full Name: Christopher Rochette
- Company Details: arup.com
- Company Position Title: Assistant BIM Designer
- Skype Name: Chris Rochette
- Mike Annear
- Full Name: Mike Annear
- Has thanked: 122 times
- Been thanked: 196 times
Re: Need to change scale of imported .xyz file in RealWorks?
Is it a simple mm / metres problem ?
Can you change the Matterport export to metres ?
Mike.
Mike.
- I have made 60-70 posts
- Full Name: Tony Millington
- Country: uk
I was just about to suggest the same thing, you can also set/change units when importing the ascii file to TRW.
Regards
Regards
Thank you both!
I got it. I was able to change the units from mm to feet, to solve the size issue.
I appreciate your guys' help!
