I have a client that is wanting to use the published walkthrough. The client uses Apple OS.
The walkthrough needs to be open using Internet Explorer 8 or above. I am trying to figure out how to use IE on the Mac platform. I have googled and come across some suggestions, but none have worked.
The "using a virtual machine" suggestion (http://osxdaily.com/2015/10/19/use-inte ... os-x-easy/) does not work because going to the modern.ie link does not work.
The using safari in developer mode and running as IE also does not work.
Is there anyone that has figured out a way of doing this? (other than running windows parallel on a mac, as the client can not be expected to purchase a windows license to run windows simultaneously on his mac just to view a walkthrough)
Walkthrough on Mac
- Full Name: Jared
- Skype Name: jaredmatthews
- Has thanked: 5 times
- Been thanked: 13 times
- Full Name: Neerav Mehta
- Company Details: Indoor Intelligence
- Company Position Title: CTO
- Been thanked: 6 times
Re: Walkthrough on Mac
If the need is temporary, then you can spin up a Windows machine on AWS, Azure or Google Cloud Compute.
