Realworks > Recap import
Muleymuel
Full Name: Sam Lynas
Company Details: PCL
Post by Muleymuel » Mon Jul 24, 2017 12:20 pm
Hello All,
In lieu of a recap pro license, is there a way to import scan data from Realworks into Recap to include each scan position, rather than the whole project cloud?
I have tried various formats and they all import into Recap as one cloud, rather than showing each scan location.
Any help would be greatly appreciated!
Sam
Vincent DENIS
Full Name: Vincent Denis
Company Details: GEOMESURE
Re: Realworks > Recap import
Post by Vincent DENIS » Mon Jul 24, 2017 1:18 pm
yeah it's possible!
Make an export in e57 format from Registration panel, not Office panel. That produce an no unified project. With each position of scan.
Let me know if it's ok.
Regards
Muleymuel
Post by Muleymuel » Mon Jul 24, 2017 2:19 pm
Thanks Vincent,
Yes, that does work, however, it seems as though you cant export your cleaned data this way, only the entire project which is a little frustrating. At least this is better than nothing, thanks again. Even more frustrating, I have just purchased a months subscription of Recap Pro yet the Realworks RCP export plug in does not work, even after uninstalling and reinstalling Realworks. :(
Does anyone know how to get the .rcp export plugin to work in Realworks?
Best,
Sam
Ryan
Full Name: Ryan Frenz
Company Details: Autodesk
Post by Ryan » Mon Jul 24, 2017 3:10 pm
Hi Sam,
I don't know anything about Realworks - but probably you need to update ReCap on the machine (latest is 4.2.1), plus start it up at least once and activate your new license. After that the plugin should work (based on my understanding if how Realworks does it).
-Ryan
Mind
Full Name: Mindaugas Juska
Company Details: Freelancing
Company Position Title: Scanning Specialist
Country: LT
Skype Name: mind.juska
Post by Mind » Mon Jul 24, 2017 3:26 pm
it is possible to export your cleaned data by scan positions. You can do this by using Scan-Based Sampling tool. This method has some issues (you will lose your scan station location, it is manual process, ...) but it is possible to do it. Here is more about it:
viewtopic.php?f=170&t=11231
MQuella
Full Name: Mike Quella
Company Details: Electrical Contractor
Company Position Title: CAD Operator
Post by MQuella » Tue Oct 31, 2017 8:51 pm
Thanks Vincent,
Best,
Sam
Sam - I had this issue as well. There is a Trimble ReCap plugin that i needed to uninstall and then reinstall for the RCP export to become active. Contact Trimble for the recap file.
It is too bad you cannot export a structured, cleaned point cloud from Realworks and put it into ReCap.
Muleymuel
Post by Muleymuel » Wed Nov 01, 2017 1:21 am
MQuella,
That was my fix too. Uninstall and reinstall. I also think this was caused because of a conflict between Realworks 10.2 and 10.3, where the plugin was being assigned to the previous version.
Sam
geedaa83
Full Name: Mohamed AbdEl-Magied
Company Details: Jatco
Company Position Title: Jatco
Country: Saudi Arabia
Skype Name: geedaa83
Post by geedaa83 » Fri Nov 24, 2017 1:31 pm
Dear All,
could you reinstall recap plugin from below link then try to export direct into recap format
https://www.dropbox.com/s/9yenyzmvqcyp9 ... n.exe?dl=0
i'm working in Trimble dealer saudi arabia and i will be willing to support and help as much as i can
Thank You
Mahmed AbdEl-Magied
+966565841792
m83abdelmaged@gmail.com
Return to “Trimble Realworks”
