Using stationcoordinates as observation in TRW
Discuss all Trimble Realworks related issues here.
soranan
Full Name: Suran Khani
Company Details: LE34
Country: Denmark
Post by soranan » Wed Oct 09, 2019 1:13 pm
Hello Laserscanningforum :)
I am used to Cyclone, when working with registration of scan stations. I have recently started working in TRW, and I miss a registration method which was in Cyclone: The option of using XYZ Coordinates (Measured with totalstation/GPS) to a scan station and use these as contraint in the adjustment.
Can anyone inform whether this is possible in TRW please?
Thank you in advance.
Best Regards
A_Axelsson
Full Name: Anders Axelsson
Company Details: AF Metrology
Country: Sweden
Re: Using stationcoordinates as observation in TRW
Post by A_Axelsson » Wed Oct 09, 2019 2:58 pm
As long as you include the station coordinate in your measured points, (the Topostation), you can create a constraint to the position of the scanstation.
//Anders
soranan
Country: Denmark
Post by soranan » Fri Oct 11, 2019 9:00 am
Hi Anders
I have det coordinates included in my topopoints, but the software is not able to find a constraint between them.
How do you create the constraint ?
\\Suran
A_Axelsson
Country: Sweden
Post by A_Axelsson » Fri Oct 11, 2019 9:38 am
Hi Suran,
In the Target Based Registration under the button "Check..", in Station View you should be able to do the operation "Match with..", by selecting the station point in each scanposition and match them with the corresponding surveyed point.
But, I do think the scanstation has to be leveled for the option to match the station to appear.
//Anders
soranan
Country: Denmark
Post by soranan » Mon Oct 14, 2019 6:18 am
Thank you Anders, i was able to make constraints between my my stations and their coordinates in my topopoints.
I want to use some C2C in the final registration together with my topopoints, since my topopoints is not sufficient for the alignment,becauseit only contains stations coordiantes.
Do you know the workflow for above mentioned scenario?
Return to “Trimble Realworks”
