MeshLab
Discuss all Mesh Lab related issues here.
Has thanked: 45 times
Been thanked: 37 times
Re: MeshLab
Post by Matt Young »
That's interesting to know, mesh painting can be an lot of fun.
I do think that Z-Brush has got to be one of the best 3D modelling, meshing and painting programs on the market. I have been using it for years and can model just about any organic or mechanical object, it really is amazing.
http://www.youtube.com/watch?v=x5ZzSe1F9IQ
If you could get point clouds into Z-Brush it would be even better.
3DForensics
Full Name: Eugene Liscio
Skype Name: eliscio
Has thanked: 4 times
Been thanked: 17 times
Re: MeshLab
Post by 3DForensics »
Matt Young wrote:I know it's free and I know that others have had great success with it, but it's never worked for me! Personally I think you get what you pay for and would go with something like 3D Reshaper or Geomagic instead.
Matt, I would agree that MeshLab is hit and miss. It has a lot of potential and some really cool tools and I think there are a lot of people using it for research or on smaller projects without so many points.
Personally, I have had a lot more success with CloudCompare where I use their implementation of poisson reconstruction. On my last project, I meshed a surface and compared it to someone else who was using Geomagic. I can tell you that the results were comparable (if not better with CloudCompare).
When using CloudCompare, you might get a "not responding" message, but I just let it cook and it has come through every time. Start small in your settings, then slowly increase to get what you want.
Eugene
blazaj
Full Name: Jiri Blazek
Country: Czech Republic
Been thanked: 5 times
Re: MeshLab
Post by blazaj »
Matt Young wrote:Okay, I installed the 1.3.0 version with no problems.
Only problem I do have is that it's very unstable to use. I can get an xyz file in as a test and can see the points. I try to run meshing (Poisson reconstruction) and it crashes every time, It's only five thousand points. I did try a .pts file but Meshlab doesn't seem to like a Leica .pts file and it's probably something to do with the header in the file. Might try .ptx and see if that is any better.
I just want to get some meshes created and then play with them in Z-Brush.
try to follow this tutorial http://meshlabstuff.blogspot.cz/2009/09 ... louds.html
First you have to subsample-unify the points and then create normals. After that poisson should work. Good luck!
Re: MeshLab
Thanks for the info and tutorial - will definitely try again with this at some point.
Mike Annear
Full Name: Mike Annear
Company Details: Mike Annear
Has thanked: 22 times
Been thanked: 58 times
Re: MeshLab
Post by Mike Annear »
I've just downloaded and tested V1.3.3 64 bit.
Very pleasantly surprised. It imports colour PTX files beautifully.
It seems far more stable than it used to be.
Mike.
Mike Annear
www.mikeannear.com
QLD, Australia.
Return to “MeshLab”
