meshing 11k sqm area
joseramilo
Full Name: Jose Ramilo
Company Details: Urban Surveys
Company Position Title: Laser Surveyor
Country: UAE
Post by joseramilo »
We're looking to mesh a historical project which is around 11k sqm. I've tried to use RealityCapture's trial version. Using a couple of exported files from Recap like e57,rcs and pts but it keeps on crashing. Also tried FaroScene 7's meshing feature but not happy with the quality of the textures. Can anyone suggest a workflow using Reality capture or suggest another software. Here's a snapshot of our project.
The machine I used is an Intel Xeon E5-2620 v3 2.40GHz
64GB RAM
NVIDIA Quadro K2200
Any suggestions would be of great help. Thanks
bdawood
Full Name: Bashar Dawood
Country: Calgary Canada
Has thanked: 4 times
Been thanked: 8 times
Re: meshing 11k sqm area
Post by bdawood »
did you try Faro Scene with multiple clip boxes in an array format and have the maximum number of meshes in each clipping box, this will dramatically improve the result.
gilles_3DR
Full Name: Gilles Monnier
Company Details: Hexagon
Been thanked: 9 times
Post by gilles_3DR »
Hi bashar,
Do not hesitate to give a try to 3dreshaper. We have lots of users meshing large amount of data.
You can get a trial version from our website:
www.3dreshaper.com
JNally
Full Name: Joe Nally
Company Details: Cork
Post by JNally »
To be honest I would say it is down to your RAM, keep an eye on it the next time you open it and see what it does. When meshing objects I typically have to split them down into tiles The latest project I did, was only 1sq/km and it was split into 6 tiles each tile using around 45GB to make each tile. If you need help I can maybe do a bit of the processing for you. I use Bentley Context Capture to do my work.
joseramilo
Country: UAE
bdawood wrote:
Mon Mar 05, 2018 7:05 am
Hi.. Yes I did give Faro Scene another try on a smaller project. Created a Project Point cloud first before creating multiple clip boxes and the result is way better. Thanks
joseramilo
Country: UAE
gilles_3Dreshaper wrote:
Mon Mar 05, 2018 9:13 am
Hi bashar,
www.3dreshaper.com
Hi Bashar. I just got the trial registration code for 3Dreshaper.. I will definitely give it a try... We have cleaned our point cloud data in Recap. What format would you suggest I export the data into 3dreshaper? TIA
joseramilo
Country: UAE
GrasstecGeomatics wrote:
Mon Mar 05, 2018 9:20 am
Hi.. That would be very cool.. Will definitely contact you If we can't work around our issues. Thank you.. :)
bdawood
Post by bdawood »
joseramilo wrote:
Tue Mar 06, 2018 4:55 am
Hi bashar,
www.3dreshaper.com
The format that is most commonly used is ply, also it depends where you want to take it from there, I will check 3d reshaper, in the next few days,
gilles_3DR
Jose, Bashar,
lots of formats can be used from Recap to 3dreshaper (or any other meshing SW): PLY, but also LAS, LAZ, PTX, E57...
The one I would recommend is E57 as this is the format that keeps most of the information (scan position, color, intensity) and can also embed pictures from the scanner (for texturing the mesh for example).
Do not hesitate to ask the suport team at 3dreshaper for some tips about how to make the best use of it!!
They'll be happy to help.
jamesworrell
Full Name: James Worrell
Been thanked: 16 times
Post by jamesworrell »
Take a squiz at ContextCapture while you are it .. might take a while, but the mesh is pretty good - also produces scaleable meshes ..
And if you fly it/photograph it - you can merge the data sets ..
11km2 is not messing around - so that is probably something you would throw at their "Centre" edition - basically a node-based processing option - multiple nodes all pulling tiles to process off the queue ..
You can rent it .. by the month .. whatever .. depending on if it is a one-off project.
Return to “Meshing Software”
