Cloud comparison software
Deformation Analysis Software for 3D Point Cloud Data eg CloudCompare
tchaper
10
Full Name: Thomas Chaperon
Company Details: Trimble
Re: Cloud comparison software
Post by tchaper »
Ruben,
As said in my original post, if you don't want to project onto a surface, you can use the '3D inspection' tool to create a 3D inspection cloud: each point of this cloud will store its distance to the other surface. You can then visualize and analyze this cloud using these stored distances. Is this the kind of thing you're looking for?
Thanks,
Thomas
RobM
I have made 90-100 posts
7
Full Name: Robin Miller
Company Details: My own boss
Been thanked: 11 times
Post by RobM »
Hi Thomas,
just came across your post and I am a little curious since I tried that in Realworks but failed.
Is there a how to or tutorial you can provide?
Rob
tchaper
10
Post by tchaper »
Hi Rob,
Running the tool is pretty straightforward: select two point clouds or a point cloud and a mesh, then, in Production configuration, go to Inspection>3D Inspection and start the tool. All you need to do next is press 'Preview'.
Once the inspection cloud is computed, you may filter it or create it directly. When the object is saved, you can run '3D inspection analyzer' to edit the color bar, filter using the distance histogram, or automatically extract clusters, e.g., objects that moved between the two scans.
I hope this helps.
Thomas
Return to “Deformation Analysis Software”
