UN ROLLING - CONE DATA
Deformation Analysis Software for 3D Point Cloud Data eg CloudCompare
NOVAMECH
Full Name: Nick Bush
Company Details: NOVAMECH
Country: New Zealand
Skype Name: novamech5
Post by NOVAMECH »
Can someone please, suggest how I might go about UN ROLLING a CONE
My project is to un-roll a cone at the bottom of a 18 meter tall Cyclone Device. I have tried Cloud Compare and Phil Nixon's - UNFURL app. with no luck.
I need to un-roll this and produce a report showing total area numerically above and below spec. I can do this with ease within PolyWorks once I have the CONE Developed out on to a flat plane.
Cloud Compare - CC Forum informs me that the CONE development does not work correctly at present.
UnFURLed Data from Phil Nixion's app - perhaps I have the orientation incorrect?
danielgm
Company Details: CloudCompare
Been thanked: 7 times
Re: UN ROLLING - CONE DATA
Post by danielgm »
Not sure what is the date of the forum message you refer to ;). Anyway if there's a bug we can always fix it :D
How far are you from what you expect?
Daniel
CloudCompare admin
http://www.cloudcompare.org/
TommyMaddox
Full Name: Tommy R Maddox III
Company Details: ONSITE3D
Has thanked: 16 times
Been thanked: 17 times
Post by TommyMaddox »
Maybe consider modeling the conical tank in 3D, and then fitting the pointcloud to it, and generating the 3D PDF deviation analysis report in Geomagic Qualify/Control/Verify (Whatever they're calling it these days).
The report will give you exactly what you're asking for without having to unfurl the surface or pointcloud for planar analysis.
I may be able to send you a sample report, I did some academic statistic analysis work with it a couple years back.
NOVAMECH
Post by NOVAMECH »
Hi Guys - Just to be clear I'm looking to - apply a 'conical' projection.
As per this image below.
Any help would be greatly appreciated - Thanks in advance
NOVAMECH
Post by NOVAMECH »
Anyone have any - Ideas on this, now everyone is back to work?
IngSayyad
Full Name: shahzad sayyad
Company Details: Ingenieurbuero Drecoll
Company Position Title: Entwicklungsingenieur
Skype Name: shah.baba_2012
Post by IngSayyad »
I don't understand why you're not applying the solution provided in image.
Anyhow, a working solution for the programmers (if you don't want to use open source solution or commercial solution)
1-write your own solution for 'conical projection'
or
2- cut your object in 10-20 cm multiple pieces and apply cylindrical projection , you can again use open source solution for that and combine these pieces.
Dr.-Ing. Shahzad Sayyad
Return to “Deformation Analysis Software”
