3d-scan to 3d-print
Discuss all 3D Prining issues here.
karrob14
Full Name: Robert Karas
Company Details: Wiener Netze GmbH
Company Position Title: 3d-geodatamanager
Country: Austria
Skype Name: karrob33
3d-scan to 3d-print
Post by karrob14 » Tue Jan 17, 2017 1:19 pm
I'm looking for a suitable way to print a laserscan point cloud on a 3d printer, which can affect the whole system (see photo), or even parts of it, or many parts that are combined to one piece, I am using a riegl vz-400i scanner, I have knowledge in auto-cad, 3ds-max, in bentley microstation and the add-on software terrasolid (terra-scan and terra-photo)
I know that this mesh must be waterproof so that the printer can interpret it properly and process it further
Does anyone know, how could it be print from the riegl-software riscan-pro to a finished 3d model?
stevenramsey
Full Name: Steven Ramsey
Company Details: 4DMax
Skype Name: steven.ramsey
Re: 3d-scan to 3d-print
Post by stevenramsey » Tue Jan 17, 2017 2:11 pm
Is it a massing model or would you need each componant as a seperate object
Steven Ramsey
Home steven.ramsey@laserscanningforum.com
Work steven@4DMax.co.uk
Mobile +44 7766 310 915
tbwester
Full Name: Thad Wester
Company Details: WeWork
Post by tbwester » Tue Jan 17, 2017 3:35 pm
With that scanner (long range), it will not be very detailed and probably have a lot of shadowing issues.
I guess it depends on your use-case, why do you need it printed?
karrob14
Country: Austria
Post by karrob14 » Wed Jan 18, 2017 6:47 am
stevenramsey wrote:Is it a massing model or would you need each componant as a seperate object
yes , you are right, the object is massive, but i need it in parts and also as the whole thing, but printing ist a request by a department in our house to have a table-model for exhibitions and verifications
karrob14
Country: Austria
Post by karrob14 » Wed Jan 18, 2017 6:51 am
tbwester wrote:With that scanner (long range), it will not be very detailed and probably have a lot of shadowing issues.
i have the possibility with this scanner to scan details in very high-resolution and as a table model in a smaller scale to print, as requested by the department, to exhibit it and to prepare for presentations
Maarten_Sepers
Full Name: Maarten Sepers
Company Details: freelancer
Company Position Title: owner
Country: Netherlands
Post by Maarten_Sepers » Wed Jan 18, 2017 10:23 am
Occasionally I'm 3D printing small excerpts from point clouds for demonstration/visualizations purposes. I'm working with heritage objects like buildings, underground spaces and excavation sites. The process from point cloud to 3d print can be, however, like others already motioned, a rather laborious process with a lot of difficulties, especially if you are aiming for high detail or working on filling up occlusions and making the model watertight.
I like to use programs like cloudcompare or meshlab to apply the Poisson Surface Reconstruction filter in order to create a mesh. Most of the times the created model needs to be 'cleaned' in modeling software like 3D max in order to remove unwanted artefacts. I know that there are also several commercial software packages available that are offering these kinds of functionalities.
I've added an example of a 3d printed underground fortress-hallway.
karrob14
Country: Austria
Post by karrob14 » Fri Jan 20, 2017 9:37 am
Return to “3D Printing”
