Lidar Velodyne VLP 16
Discuss all your Aerial Lidar topics here including, Aeroplane, Helicopter & UAV
ludiga
Full Name: Luca Di Gaetano
Company Details: LTS Land Technology and Services srl
Company Position Title: Work Experience
Country: Italy - Treviso
Post by ludiga »
Hello guys,
I head the Velodyne Lidar VLP 16.
The lidar interfaces with the software Veloview to record frames and create the file pcap.
Now the point is this, from pcap files I can export all frames into individual csv file, so I end up with thousands of csv file!!!
How can I merge all the csv file? or I can process it by pcap to have a file LAS or other?
The velodyne has Garmin GPS 19x HVS, with PPS to a 1 hz.
I tried playing with the software wireshark but nothing.
I gave the timestamp for every frame.
Thanks a lot
r_oliveira
I have made 80-90 posts
Full Name: Ricardo Oliveira
Company Details: Murphy Surveys Ltd
Company Position Title: Head of Digital Engineering
Re: Lidar Velodyne VLP 16
Post by r_oliveira »
Use powershell for instance
Code: Select all
Get-Content *.csv | Set-Content output.txt
Has thanked: 40 times
Been thanked: 18 times
Post by Jason Warren »
Or at the Windows 7 cmd line:
Code: Select all
type mydatafiles*.csv > mybigdatafile.csv
Do you have a sample pcap file you can share with us, and highlight the frames you wish to parse out. A simple VB app maybe able to help here... ;)
Or you maybe able to save the data out of VeloView as sequential *.vtp files. Import them into ParaView, and then export out as a single *.csv.... worth investigating.
I don't think Cloudcompare or FME can import pcap files, but it would be good to know for sure. Ideally you want VeloView to capture the data in real-time and save into a database.... then you can export whatever you like.
Hope this helps...
Return to “Aerial Lidar”
