We are having trouble getting point cloud file in .RCP format with good quality for viewing panoramic images.
Workflow: 1 - Scans with Leica, model RTC360.
2 - Processing in Cyclone Register360.
3 - Export of files in formats: E57.
4 - Obtaining a file in RCP format in the RECAP Version 2022 software.
Report: 1 - When we export via Cyclone the files in E57 format and import them to RECAP to generate an RCP file, we get a low quality view of the panoramic images as shown in annex 1.2 - Places where points were deleted within Cyclone are without image preview.
Image 1: Cleaning performed on Cyclone. Exporting the e57 file and generating the RCP file in RECAP.
Obs.: Obtaining the RCP file from a FARO brand scanner, through the SCENE software we have the file with the presence of panoramic image and better image resolution. We would like to know what workflow we need to follow so that our RCP file has the panoramic image not only where the points are present. Unfortunately, it is unavoidable that our customers compare the point clouds of our equipment (RTC360) with those obtained on the FARO equipment, as their 360º image view is proving superior (Image 2).
Poor Panoramic Image Viewing on Recap
- Full Name: Carlos Alberto Queiroz Junior
- Company Details: Dont have
- Company Position Title: Dont have
- Country: Brasil
- Full Name: Adam Berta
- Country: Hungary
- Has thanked: 49 times
- Been thanked: 292 times
Re: Poor Panoramic Image Viewing on Recap
within leica environments you can only have images in recap if you pay for publisher pro subscription and then export rcp directly from register360 or cyclone register. You need to export separated setups.
- Full Name: Kevin Grover
- Company Details: McElhanney
- Company Position Title: Advanced Research and Technology Leader
- Been thanked: 5 times
So this also depends on what version of Register360 you are using. Version 2020.1 has a new option for "Export structured E57 in Compatibility Format" which is to be more compatible with Recap (and you don't need the Publisher Pro license). The release notes for this version outline the update.
You need to have that checked as being turned on, in order to get the proper imagery into Recap.
All part of the debacle with the E57 file structure which all software firms seem to read / write differently (especially images).
- Country: Hungary
I think you mean 2021.X.X release but i exported few setups just for the test, and it didn't exported the photos to recap, maybe need a specific recap version as well?kevin.grover wrote: ↑Fri Jun 18, 2021 6:40 pm So this also depends on what version of Register360 you are using. Version 2020.1 has a new option for "Export structured E57 in Compatibility Format" which is to be more compatible with Recap (and you don't need the Publisher Pro license). The release notes for this version outline the update.
- I have made 60-70 posts
- Full Name: Michael H
- Company Details: CFM
- Country: NB Canada
- Has thanked: 5 times
- Been thanked: 7 times
How do you export images with the point cloud to .rcp within Cyclone register? I can only get the points to export.
- Country: Hungary
I don't have register license and never used that i just heard that it can be done, but the publisher license is required and the pointcloud cannot be unified and you need to export the setups not the model space (i'm not sure if used the terms correctly here), And an additional thing is that you might need to create the multiimages... But as i said i never used register, just reg 360.
And i suppose publisher pro is a must to export to rcp.
- Country: Hungary
but it certainly makes the e57s unreadable by PDAL, so it would only worth the effort to preconvert the setups before pdal if it would realy create normal panoramic image in recap, but it might doesjust require a newer recap? I've used 2019 version, usually we never bother the users with recap if it is not a must, because to view images in recap is just painfully slow.kevin.grover wrote: ↑Fri Jun 18, 2021 6:40 pm So this also depends on what version of Register360 you are using. Version 2020.1 has a new option for "Export structured E57 in Compatibility Format" which is to be more compatible with Recap (and you don't need the Publisher Pro license). The release notes for this version outline the update.
I was just told by Leica support that Recap doesn't support Leica photos. The bubble views published from Cyclone will only have the colored point cloud. This is quite the disappointment.
