While testing Recap and actually liking the cleanup feature i found out it will be removed this friday
https://forums.autodesk.com/t5/recap-fo ... -p/8282058
Project Cleanup and Mesh will be removed
- Mortum
- Full Name: Robin van der Molen
- Company Details: ----
- Company Position Title: 3D Scanmonkey
- Country: Netherlands
- Has thanked: 3 times
Sincerely, Robin van der Molen
Gear and Software:
Ye olde: Faro Photon 120
Faro Scene: 2023
Geomagic Design X
Autodesk Recap
Gear and Software:
Faro Scene: 2023
Geomagic Design X
Autodesk Recap
- Full Name: julien A
- Company Details: historic preservation
- Company Position Title: intern
- Country: france
Re: Project Cleanup and Mesh will be removed
I've tested the automatic clean-up tool, which as been a beta test since 2016, on many projects and I can assure you it does not work as well as expected.
- Sometimes it cleans up too much, you will lose information.
- Sometimes it removes a few points but you need to complete the operation manually.
- and sometimes it just doesn't find anything to remove (with an explicitly clear message)
I asked for information about these behaviors on their forum and had no answer except for this same message you posted.
That's too bad it doesn't work and they won't try to make it work any more.
