BLK360 to Recap filename warning
Mrk
Full Name: Mark Lane
Company Details: Convert3D
Company Position Title: BIM guy
Post by Mrk » Tue Sep 25, 2018 6:09 am
I've had an issue when transferring scans from the iPad to Recap Pro - when the filename contains a forward slash (/), Recap will mistake the project as a file-path, rather than a file name. Resulting in the rcs files not coming across into the support folder.
I can't find a way to correct this afterwards, other than to do a rescan.
Has anybody else come across this one?
fosser2
Full Name: Andrew
Company Details: Stainless Specialists Inc
Re: BLK360 to Recap filename warning
Post by fosser2 » Wed Dec 26, 2018 10:58 pm
Happened to us as well. What we did was make a new project without the / character. And then we just copied all of the scans back off of the laser to the iPad and re-register. Obviously not doing that is preferred but at least you don't actually have to rescan again...
jlggps
Full Name: John Garison
Company Details: Cardno
Company Position Title: Geomatics Specialist
Skype Name: john.garrison@cardno.com
Post by jlggps » Sun Feb 10, 2019 9:54 am
I too have come across this issue where the crew(s) performing the scans named their scans after the closest road intersection. I had files with names like "1st/A-WMH1" and ReCap was unable to find the data files. They where there in a sub-folder called "1st" in the structured ReCap Scan folder. I tried opening the *.RCS file(s) in a text editor but noticed it appeared to compressed data. I tried 7Zip (freeware) and found that *.RCS files are just a XML file inside a compressed container file. At that point, I opened the *.RCS files with 7Zip, then edited XML data file "inside" to remove the "/" and/or renamed each scan appropriately. After that, I just renamed each *.RCS scan file to be consistent with what I renamed them to in the XML file(s). Worked like a charm... it only took a few minutes to fix each scan site for all the other structured scans.
This goes without saying but I did let the crew(s) responsible for the data collection efforts know of the BLK360 scan naming issue so to avoid any further occurrences.
I am glad I was able to get the Recap to find and use the data... I was told the crews traveled 1,600+ miles (one-way) to the project site to do the work. It would not of been pretty if the crews had to go back and rescan these structures. …and I am 1,900 miles away in the opposite direction from the project.
Hope this helps someone should they encounter this issue.
Thanks,
John
