Colouring points by distance from a plane in Autocad
Discuss Autodesk ReCap Studio software here.
dagenhamdave4
12
Full Name: David Railton
Company Details: Met Police CAMB
Post by dagenhamdave4 »
I don't know if anyone out there can help with this one but is there a way to apply a shader (much like the shade by elevation function) to point cloud data in Autocad based on the current UCS? To elucidate; I need to draw an elevation and to bring out the fine ornate detail I'd like to colour the data based on its range from the current plane I'm working on, however Recap only recognises the world UCS as the basis for shading by elevation. Is there a way to force Recap to ignore the world UCS and treat the current plane as the reference surface for colouring by range?
This probably isn't the clearest question ever posed, but if someone has any ideas they'd be much appreciated!
CWickersham
I have made 60-70 posts
8
Full Name: Caleb Wickersham
Company Details: EMJ Corporation
Company Position Title: Virtual Construction Engineer
Re: Colouring points by distance from a plane in Autocad
Post by CWickersham »
If I read your question right, I think this is the option you are looking for:
http://imgur.com/a/PcaU5
Caleb Wickersham
emjcorp.com
dagenhamdave4
12
Caleb,
Thanks for your response - do you know if it's possible to do that from a vertical plane defined in AutoCAD, so that your ramp stretches horizontally away from the plane? I'd like to trick AutoCAD into thinking the up direction is perpendicular to where it normally is, as it were... I might not have been that clear in my question!
Phil Marsh
16
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Has thanked: 117 times
Been thanked: 36 times
Post by Phil Marsh »
Do you have cyclone? If so you can export the cloud with the Z+Y axis flipped then take this into Recap.
LASER SCANNING FORUM
dagenhamdave4
12
That's a good shout Phil, looking at acquiring cyclone so that might be the best option in the future. Cheers
Ryan
15
Full Name: Ryan Frenz
Company Details: Autodesk
Post by Ryan »
If AutoCAD can shade by elevation, you could probably do this by adjusting the coordinate system in ReCap (using the 'Update Origin' tool). It allows you to set a UCS based on a picked point (origin) and two planes (X and Z). You can adjust any or all of the three to set 'up' however you'd like. Might be a workaround.
-Ryan
dagenhamdave4
12
Ryan, I presume that when you export as either RCP or RCS for inserting into autocad this change is maintained? Thanks for your input, much appreciated.
Dave
Tanguy Nédélec
I have made 90-100 posts
8
Full Name: NEDELEC Tanguy
Company Details: Prigent et Associes
Company Position Title: Surveyor - nooks and crannies explorer
Has thanked: 7 times
Been thanked: 19 times
Post by Tanguy Nédélec »
In AutoCAD the elevation shading can only be applied along the world UCS Z axis. You can rotate the point cloud itself to get what you want. No need to do it in Recap, you can do it in AutoCAD directly.
3DForensics
Honorary Member
Honorary Member
14
Full Name: Eugene Liscio
Skype Name: eliscio
Has thanked: 13 times
Been thanked: 70 times
Post by 3DForensics »
Why not just do it in CloudCompare and then export the coloured point cloud from there?
Least
I have made 80-90 posts
11
Full Name: Patrick
Company Details: 360G
Country: uk
Has thanked: 10 times
Been thanked: 13 times
Post by Least »
or do it on the fly with Undet in AutoCAD
https://youtu.be/QvnCq47JMPs?t=35
