Segmentation of Point Cloud - Riegl Format
Discuss Autodesk ReCap Studio software here.
Terrence_SA
12
Full Name: Terrence
Company Details: MHP Geomatics
Company Position Title: Professional Land Surveyor
Country: South Africa
Skype Name: terrence.elliott
Post by Terrence_SA »
We have a number of clients who work in Autodesk and require the functionality that the "new" Autodesk object snaps offer.
(https://knowledge.autodesk.com/support/ ... 0-htm.html
The documentation refers to "segmentation of the point cloud file during Recap processing".
We have not managed to successfully create a "segmented" point cloud that works with these snaps from data captured with the Riegl scanner. The data pulls into Recap fine - point clolours, intensity and normals display correctly but on use in Autodesk the snaps do not work.
Could a user or somebody from Recap assist here?
Is there a specific format we should be bringing the data in for the segmentation to occur?
kpob46
I have made 100> posts
9
Full Name: Kyle OBrien
Company Details: Nutrien
Company Position Title: Mine Technologist
Has thanked: 18 times
Been thanked: 23 times
Re: Segmentation of Point Cloud - Riegl Format
Post by kpob46 »
Do you have the 3D Object Snap turned on in AutoCAD?
If not, type "dsettings", go to the 3D Object Snap tab and check the box to turn it on. You can also select which points you want to snap to (ie. node, intersection, etc)
Ryan
15
Full Name: Ryan Frenz
Company Details: Autodesk
Post by Ryan »
AutoCAD will only snap to 'structured' scan data - this effectively is data created from FLS/ZFS/PTX/PTG and some E57 files.
This is a limitation of AutoCAD that we hope to improve in the future. From Riegl scanners you'll need to get the data to PTX most likely.
Ryan
DONATSCH AG
12
Full Name: Fadri Jecklin
Company Details: Civil Engineering an Surveying
Company Position Title: Lead Laserscanning
Country: CH
Has thanked: 10 times
Post by DONATSCH AG »
i was just in contact with Riegl, about ptx export.
It should be back soon. The ptx interface was canceled in Riscan V2.0
