Deformation analysis statistics
- I have made 50-60 posts
- Full Name: Julian
- Company Details: University
- Company Position Title: Student
i am doing a deformation analysis between a mesh and a point cloud. As a result i am getting a histogram with the results. I did this between two epoches on a wall with HDS7000 to analyse the scanners accuracy. How would you guys interpretate the accuracy of HDS 7000 in this picture?
Is it possible to get statistical results like standard deviation or a deviation distribution? Here is a screenshot of the result:
@Gilles (3DReshaper): i got a student license from your company for this programm but i dont habve full access to the inspection tools. Is it possible to get a full access student license because it is used for my bachelor's degree?
Thank you
StuEv
Thank you
StuEv
- 3DForensics
- Honorary Member
- Full Name: Eugene Liscio
- Skype Name: eliscio
- Has thanked: 13 times
- Been thanked: 70 times
Re: Deformation analysis statistics
What is the reference mesh? Is it a converted point cloud or a CAD model?
- Full Name: Julian
- 3DForensics
- Honorary Member
Only reason I ask is that if there is any simplification of the points/mesh and you are looking for fine results, then it could be a little difficult to interpret.
- Full Name: Julian
hmm what would you suggest to make a good mesh in 3dreshaper?
i have a point cloud density of 1cm. i made the mesh with 2cm mean space between points and hole detection of 6cm.after that i interpolatet existing points to refine the mesh.
I want to compare the mesh with a point cloud to investigate the accuracy of hds 7000 scans.
- 3DForensics
- Honorary Member
Can you try cloud to cloud distances in CloudCompare and see how that compares to your mesh to cloud result?
I would keep the original point cloud densities as they are and no need to decimate.
Eugene
Eugene
- gilles_3DR
- Full Name: Gilles Monnier
- Company Details: Hexagon
- Country: France
- Been thanked: 28 times
Hi StuEv,
yes, for sure, you can request for a full temporary license to get all the inspection tools you need for this study.
We'd be happy to help.
In general, I would assume that comparing a cloud to a mesh is more precise than comparing a cloud to another cloud as the projection of a point onto a cloud is more likely to be method dependent.
The main reason to me is that the mesh you will create in Reshaper will be located in the middle of the noise thickness! Creating a good mesh for this application will therefore depend on the point density and an estimated value of scanner accuracy! If you need more help on how to create a good mesh for this application in Reshaper, do not hesitate to ask!
Anyhow, the cloud to cloud inspection will be available in Reshaper in the 2016 version which will most likely be available as a beta version in 4-5 weeks (just finalized implementation and currently running quality checks)!
This way, the 2 methods will be available for comparison.
About statistics distribution, in the image you shared, you can see the percentage of point within the deviation values. This is what I would call statistics distribution... What else would you expect?
About standard distribution, I would suggest to export your point cloud to csv and then evaluate the standard deviation in excel... (looks like you are showing off a missing functionality in Reshaper!)
- Full Name: Julian
Hey Gilles,
thanks for your reply!
Well i have one Point cloud which i thinned out by unifying it in Leica cyclone with a mean space of 2cm.
After Unifying, i still have 1cm point spacing and thats what i want.
Now to create a mesh for deformation analysis, i choose the Mesh in two steps method. In the first Step i selected a mean space between meshed points of 2cm and filling holes with 6cm. I did 2cm because if choose 1cm i get many holes in my point cloud . in the next step i refine my mesh with points of the point cloud and after that i smooth out the mesh. For the second mesh i have a bad spacing because the point cloud has a spacing in the middle of 6mm and in left and right direction up to 60mm!!! what would you suggest to do with it?
I already asked for a full license for 3dreshaper but i only get the automatic answering with the student license.
I also sent the filled form to get the full license :/.
Thank you all for your great help
StuEv
StuEv
- gilles_3DR
- Country: France
with 1cm point spacing, what is the size of your point cloud? (how many points?)
- Full Name: Julian
