hello
I scanned a dike of a dam by the Leica c10 scanstation, I made the station by free station
but then the export of my scans from cyclone basic in e57 format and introduces them to 3d Reshaper
I find that the scans are poorly georeferenced .
your help please
how can i export them properly
cyclone basic emergency
- Full Name: bedrane walid
- Company Details: space technology center
- Company Position Title: geodetic engineer
- Country: Algeria
- Skype Name: walid962012_1
- Full Name: Major Domo
- Company Details: VeritasVfx
- Company Position Title: ceo
- Country: Portugal
- Has thanked: 17 times
- Been thanked: 53 times
Re: cyclone basic emergency
It might help if you describe your workflow with a bit more detail.
Did you scan targets?
HDS or B&W?
On board detection?
Did you register on board?
Did you register in Cyclone?
Do you have survey control?
If you registered onboard it pays to still re-register in Cyclone, as it almost always does a better job than the scanner itself. The C10 has a 500'ish Mhz processor, and not much RAM, if you have loads of stations, there are only so many iterations it goes trough before stopping, you can crank these up much higher on Cyclone.
HDS or B&W?
On board detection?
- gilles_3DR
- Full Name: Gilles Monnier
- Company Details: Hexagon
- Country: France
- Been thanked: 28 times
There are several ways to export to e57 from cyclone.
The right way to go is through the project explorer with a right click to get the contextual menu
Hope this helps
Hope this helps
