clipping box not effective for building extractor
npara
Full Name: Scott Nelson
Company Details: Nelson Parametrics Inc
Post by npara »
For some reason, if I create a clipping box for the first floor only, and have it activated, the building extractor function will still 'see' the clipped points when I try to select a plane. If I toggle the 'show/hide temporary clipped objects' I can see that my first floor wall click actually seclect for eg. the second floor ceiling.
Is it required to split the cloud with the clipping group in order to get accurate selections?
Thanks.
gilles_3DR
Full Name: Gilles Monnier
Company Details: Technodigit
Re: clipping box not effective for building extractor
Post by gilles_3DR »
Hi Scott,
which version are you using? 3DReshaper or Cyclone 3DR?
This has been fixed recently in Cyclone 3DR and works like a charm!!
npara
Post by npara »
Thanks, that works better. Question: is it worth it to extract floors and walls first before running building extractor?
gilles_3DR
All,
Just to be more precise in the way the limit boxes work in general in Cyclone 3DR and in particular within the building extractor tool.
The limit slice/plane/boxes offer a way to limit the view to what is defined but the database below is not modified.
This way, one can easily work for example when processing the data below and limit the view to 1 given floor, modify the area to be visible/hidden and continue to the next floor. See example blow:
Would you have only one floor to process, my recommendation would be to "clean" the input point cloud to remove all points on the floor or on the ceiling, for example using the walls and floor filter.
Return to “Cyclone 3DR”
