cClassic 3DR v Cyclone 3dr
graham.watson
Full Name: Graham Watson
Company Details: Road Science
Company Position Title: Technical Lead - High Speed Data
Country: New Zealand
Post by graham.watson »
We have found if we mesh the same point cloud in both versions, using the 2 step method with the same parameters that the meshes are totally different.
Red is new version
sim.herrod
I have made 100> posts
Full Name: Simeon Herrod
Company Position Title: Scan and CAD Tech
Has thanked: 9 times
Been thanked: 9 times
Re: cClassic 3DR v Cyclone 3dr
Post by sim.herrod »
Graham, you're not exactly inspiring confidence in someone who has barely got to grips with 'classic' 3DR...
gilles_3DR
Full Name: Gilles Monnier
Company Details: Hexagon
Post by gilles_3DR »
Hi Graham,
in Cyclone 3DR, there is a small change in the 2nd step of the 2 steps meshing workflow compared to 3DReshaper:
  • In the second step of 3DReshaper ("classic 3DR"), the parameters proposed when one enters the command are the ones that the user entered on his computer last time he ran the refine step (the second step).
  • In the second step of Cyclone 3DR, the parameters are proposed based on the value entered by the user in the 1st step.
There are several reasons for proposing default values:
  1. Setting these values can be quite tedious depending on the scanned data. With this first proposal, one get a rough idea of which parameters to enter. First value set which you can then refine or completely override in order to improve the results!
  2. Processing the same data set on different computers now gives the same result by default!
I hope these explanations help.
Let me know if, applying the same parameters in the second step doesn't give the same result of course. But this would be very surprising!
pburrows145
Full Name: Paul Burrows
Has thanked: 20 times
Been thanked: 28 times
Post by pburrows145 »
graham.watson wrote:
Mon Nov 04, 2019 11:57 pm
We have found if we mesh the same point cloud in both versions, using the 2 step method with the same parameters that the meshes are totally different.Mesh New vs Old.jpg
Red is new version
I am seeing an general improvement in all mesh results in Cyclone 3DR, and it certainly seems faster too.
sim.herrod
gilles_3Dreshaper wrote:
Tue Nov 05, 2019 9:01 am
Hi Graham,
Thank you for the explanation Gilles...confidence in installing new version restored.
graham.watson
Another quick one. While working on a point cloud doing kerb extraction. the point cloud has turned this grey colour and I don't seem to be able to get it back to the itensity values. It will change back to rgb though
graham.watson
Sorry, should have said, that this is in classic 3DR
gilles_3DR
Hmm...
Would it be possible for you to share the point cloud? So that we try to reproduce what you describe?
chrisg.cmg
Full Name: Chris Gilling
Company Details: Mcelhanney
Post by chrisg.cmg »
Quick questions hopefully: how do you open multiple projects at once? I can't seem to get multiple tabs going like in classic 3DR. Seems like multiple instances of C3DR will open with one license but you can't copy between them.
gilles_3DR
Hi Chris,
You're right, we decided to go to single document within a given instance of Cyclone 3DR compared to multiple document for 3DReshaper.
The main reason for this decision is that we tried to make Cyclone 3DR as simple as we could think of. And we have several ideas where tabs can be used very efficiently to something different than different documents. True to say that these ideas have not been implemented yet!
As you pointed out, the main drawback right now with this decision is that objects can't be copied/pasted for now between different instances of Cyclone 3DR. We are working on it right now and hope to provide this functionality as soon as possible.
By then, the tip is to export meshes/clouds to external format and then import to the other document...
Return to “Leica Cyclone 3DR”
