Thickness of a cross-section
Discuss all 3DReshaper related issues here.
gilles_3Dreshaper
Full Name: Gilles Monnier
Company Details: Technodigit
Re: Thickness of a cross-section
Post by gilles_3Dreshaper » Thu Apr 04, 2019 9:06 pm
So, in order to make sure that a clipping plane is perpendicular to an axis, you have to select it before launching the command to create the clipping plane.
Be sure that only the axis is created.
With is workflow, one can only move the clipping plane along (ie perpendicular to) the axis.
If several elements are selected before launching the command, the logic is to create a default clipping plane (ie which you can rotate) but only clipping the selected items.
Gilles
3DReshaper Manager
http://www.3dreshaper.com
mehmetvozdogan
Full Name: Mehmet Volkan Ozdogan
Company Details: Dokuz Eylul University
Company Position Title: Research Assistant
Country: Turkey
Post by mehmetvozdogan » Tue Apr 09, 2019 8:10 pm
Hi Gilles,
Thank you for your answer, drawing axis with line instead of polyline solve the problem..
Return to “3DReshaper”
