Thickness of a cross-section
mehmetvozdogan
Full Name: Mehmet Volkan Ozdogan
Company Details: Dokuz Eylul University
Company Position Title: Research Assistant
Country: Turkey
Post by mehmetvozdogan »
I think it is an easy question, but how can i arrange the thickness of a cross-section taken from a point cloud data. i could not find. I do not mean spacing. I mean thickness of cross-section.
Actually i need 2D cross section data from 3d point cloud with minimum thickness. How can i get 2D cross section data.
Thank you..
kpob46
Full Name: Kyle OBrien
Company Details: Nutrien
Company Position Title: Mine Technologist
Re: Thickness of a cross-section
Post by kpob46 »
If you double-click on the clipping plane or right-click on it and go to edit, you can change the depth of the cross section.
gilles_3DR
Full Name: Gilles Monnier
Company Details: Hexagon
Been thanked: 9 times
Post by gilles_3DR »
The proposal from Kyle is correct.
Once you have created the clipping plane with the right depth, you can also separate this slice of the point cloud in a more permanent way with the tool cloud/separate with/visibility.
If what you are looking for is different, do not hesitate to ask some more!
mehmetvozdogan
Country: Turkey
I use create along axis tab. I do not create a clipping plane. Is it possible to solve from create along axis options?
gilles_3DR
Hi Mehmet,
The outputs of the "create along axis" command are polylines: vertices connected by segments. Usually created as a section of a mesh at regular intervals along a curve.
This tool also allows to create polylines onto a point cloud. In this case, you can define the depth of the point cloud on which the polyline should be created at each section.
I would say that the polylines created on a mesh are much cleaner. This is why we promote this workflow.
In order to slice a point cloud along a curve, I would recommend to create a clipping plane following the input curve.
See a video of how to do it here:
youtu.be/1V2VoSx3vHk
Note: when a clipping plane is activated, you can lock a view to be always parallel to the plane: when moving the plane with the ctrl+wheel, the locked view will follow. To activate this, look for the lock on the bottom right of the software.
mehmetvozdogan
Country: Turkey
Thank you Gilles and Kyle
I have done it. It is so easy...
gilles_3DR
Good to hear! ;)
Any chance you can share a video of what you achieved?
mehmetvozdogan
Country: Turkey
You can find the video of my work below..
https://www.youtube.com/watch?v=ZuUqfp4 ... e=youtu.be
Phil Marsh
Full Name: Phil Marsh
Skype Name: phil.h.marsh
Has thanked: 31 times
Been thanked: 11 times
Post by Phil Marsh »
mehmetvozdogan wrote:
Tue Apr 02, 2019 9:38 pm
youtu.be/ZuUqfp4VQCA
LASER SCANNING FORUM
mehmetvozdogan
Country: Turkey
I have one more question about cross section with clipping plane
The clipping plane have to be perpendicular to my long axis of my tunnel. How can i ensure that?
Return to “Leica Cyclone 3DR”
