3D Reshaper Spherical Tank
Mansour21
Full Name: Mansour Ali
Company Details: Saudi Aramco
Company Position Title: Geomatics Engineer
Country: Saudi Arabia
Post by Mansour21 »
Hi
I've tried a demo license of 3D Reshaper processing cylindrical tanks and I'm really impressed by the results. I'm wondering if it can do the same with the spherical tanks? if not, is there any suggestion for a software/method to process such tanks? Thanks..
Mansour
gilles_3DR
Full Name: Gilles Monnier
Company Details: Hexagon
Been thanked: 9 times
Re: 3D Reshaper Spherical Tank
Post by gilles_3DR »
Hi Mansour,
Thx for the feedback on cylindrical tank implementation.
The beauty of the tank module in 3dreshaper is that the user is guided all the way through, with all values from the API which are directly provided.
But, you could use all individual tools from 3dreshaper to obtain the exact same results. Of course, you would need to know where is the tool to create the best cylinder, to cut the shell from the bottom and the top, to create the color map deviation, to unroll...
What I mean here is that what you can do in a non guided way for cylindrical tanks in 3dreshaper, you can do it on spherical tank of course!
Mansour21
Post by Mansour21 »
Hi Gilles,
Thanks for your reply. I’m going to receive data of a spherical tank after two weeks from now. I’ll try processing it with 3DReshaper and I’ll put my feedback here.
mrhunt
Full Name: Michael H
Company Details: CFM
Country: NB Canada
Has thanked: 3 times
Post by mrhunt »
gilles_3Dreshaper wrote:
Sun Mar 03, 2019 8:26 pm
Hi Mansour,
Gilles,
Is there a way to create the cross sections (as in the tank module) using a cone shaped tank? I have created the mesh and best fit cone but would like to see the cross sections with radii and deviations from best fit cone.
gilles_3DR
Hi Michael,
In order to create sections on a cone, you'll need to:
1. Create a mesh out of it: select the cone and just launch the Construct / Mesh / From geometries (see image below).
2. Create the sections for both the "Cone mesh" and the mesh coming from the measurements (Polyline planar sections)
3. Group each sections into a group of section
3.a. Select the sections from the cone mesh and group them with the Home / Group tool (maybe rename as "Cone sections"
3.b. Select the sections from the measurement mesh and group them (proposed name: "measured sections")
4. Select the cone sections and then the measured sections and run the inspection (Measure / Compare/Inspect - see 2nd image below)
Let me know how that goes!
Return to “Leica Cyclone 3DR”
