Alignment of two point cloud
mehmetvozdogan
Full Name: Mehmet Volkan Ozdogan
Company Details: Dokuz Eylul University
Company Position Title: Research Assistant
Country: Turkey
Post by mehmetvozdogan »
I am new with 3D reshaper,
I have two registered point cloud data of same place. They are taken in various dates.
But both of the point cloud have own coordinate system.
I need to align (not register) the both point clouds to get cross sections for seeing the change..
I can manually align it from transform menu. However precision of alignment depends on user.
Is there any other methods for alignment of two point cloud data for more precision leveling.
Thank you...
gilles_3DR
Full Name: Gilles Monnier
Company Details: Hexagon
Been thanked: 9 times
Re: Alignment of two point cloud
Post by gilles_3DR »
Hi Mehmet,
How about applying a best fit alignment between the 2 clouds?
The user first needs to align roughly the 2 point clouds and then the software will minimize the distance between the 2 clouds...
mehmetvozdogan
Country: Turkey
Hi Giles,
Thank you for your answer,
Is the best fit alignment kind of a registration method? or is it using for only align the two point clouds?
I am trying to align two point cloud of an underground structure. So if it is a kind of registration, it applies transformation and will change the shape of one point cloud to align with the reference. So this will cause an error in change detection analyses
Thank you...
paranoiahasu
Full Name: ANIL
Company Details: Mergen3D
Country: Turkey
Has thanked: 6 times
Been thanked: 4 times
Post by paranoiahasu »
Hi Mehmet
Best fit alignment, rotates your point cloud as a cluster in different axis' instead of transform your coordinate values point by point (this should keep scale factor)
gilles_3DR
The result of the best fit function is a rigid body transformation matrix which is then applied to one of the point cloud. So, no modification in the shape of the point cloud!
You can apply it onto other objects than point clouds: best fit a point cloud onto a mesh, a mesh onto a mesh, a point cloud onto a CAD, a polyline onto a mesh, a polyline onto another polyline...
You can also best fit several point clouds at a time. But there is here a limitation in terms number of point clouds that can be processed!
Another nice feature is that you can block some degrees of freedom, for example, if the scans are levelled, you can force the best fit algorithm to avoid any modifications of the Z axis.
davegrrr
Full Name: David Gray
Company Details: Correvate Limited
Company Position Title: Head of Marketing
Skype Name: David Gray
Post by davegrrr »
mehmetvozdogan wrote:
Mon Feb 04, 2019 4:52 pm
Hi Mehmet,
Are you saying you want to align (but not register) two completely different data sets, or scenes?
Best, David
David Gray, Head of Marketing
Vercator software - fast, automatic point cloud registration • vercator.com
Made by Correvate Ltd
mehmetvozdogan
Country: Turkey
davegrrr wrote:
Tue Feb 05, 2019 11:17 am
Hi Mehmet,
Best, David
Hi David,
Yes it is definetly what i want to do. I think Gilles gave me the answer..
Thank you.
mehmetvozdogan
Country: Turkey
gilles_3Dreshaper wrote:
Tue Feb 05, 2019 7:51 am
Hi again Gilles,
Thank you for your explanation, i think it will work for me.
But i want to ask one more think, there is a best fit registration button under transfrom menu, is that what you mean with best fit function??
Thank you for your helps
Mehmet.
gilles_3DR
Yes exactly!
Did you find your way with this command?
Before launching the command, select the 2 point clouds. The 1st selected one will not move.
The 2nd one will move!
mehmetvozdogan
Country: Turkey
Tue Feb 05, 2019 10:27 pm
Yes exactly!
Thank you Gilles,
Perfectly done..
Mehmet
Return to “Leica Cyclone 3DR”
