Delete points by intensity
Discuss all 3DReshaper related issues here.
MalteHC
Full Name: Malte Holm
Company Details: TLS
Country: Norway
Post by MalteHC » Fri Jun 08, 2018 8:57 am
Hi All
I have a pointcloud, where i want to clean out points, that doesnt concern the steel contruction. By changing the range in the itensity, i can see that i can filter out almost alle the non steel points, by itensity. Does anyone know if, it is possible to delete points in 3DReshaber by itensity?
gilles_3Dreshaper
Full Name: Gilles Monnier
Company Details: Technodigit
Re: Delete points by intensity
Post by gilles_3Dreshaper » Fri Jun 08, 2018 9:08 am
Hi HC,
this is one of the new feature from the 2018 version: Cloud/Automatic filter by Inspection value.
See images below.
Image 1: the initial cloud with all points colored according to intensity.
Image 2: the points inside a given range of intensity are isolated
Image 3: the points outside a given range of intensity are isolated
From this command, you can keep:
  • The 2 clouds (the one with the points inside the range AND the one with the points outside the range)
  • Only the cloud with the points INSIDE the range but get rid of the points OUTSIDE the range
  • Only the cloud with the points OUTSIDE the range but get rid of the points INSIDE the range
Gilles
3DReshaper Manager
http://www.3dreshaper.com
MalteHC
Country: Norway
Post by MalteHC » Mon Jun 11, 2018 8:22 am
Thank you very much!
Return to “3DReshaper”
