Delete points by intensity
MalteHC
Full Name: Malte Holm
Company Details: TLS
Country: Norway
Post by MalteHC »
Hi All
I have a pointcloud, where i want to clean out points, that doesnt concern the steel contruction. By changing the range in the itensity, i can see that i can filter out almost alle the non steel points, by itensity. Does anyone know if, it is possible to delete points in 3DReshaber by itensity?
gilles_3DR
Full Name: Gilles Monnier
Company Details: Hexagon
Been thanked: 9 times
Re: Delete points by intensity
Post by gilles_3DR »
Hi HC,
this is one of the new feature from the 2018 version: Cloud/Automatic filter by Inspection value.
See images below.
Image 1: the initial cloud with all points colored according to intensity.
Image 2: the points inside a given range of intensity are isolated
Image 3: the points outside a given range of intensity are isolated
From this command, you can keep:
  • The 2 clouds (the one with the points inside the range AND the one with the points outside the range)
  • Only the cloud with the points INSIDE the range but get rid of the points OUTSIDE the range
  • Only the cloud with the points OUTSIDE the range but get rid of the points INSIDE the range
MalteHC
Country: Norway
Post by MalteHC »
Thank you very much!
Return to “Leica Cyclone 3DR”
