Mesh Color - Same for Normal and Inverted Surfaces.
Discuss all 3DReshaper related issues here.
andrewdroth
Full Name: Andrew Roth
Company Details: Kova Engineering
Company Position Title: Technologist
Post by andrewdroth » Wed Jun 06, 2018 8:35 pm
Is there a way I can color the normal and inverted mesh surfaced created from a CAD file as the same color? I'm interested in using the mesh for report illustration purposes.
andrewdroth
Re: Mesh Color - Same for Normal and Inverted Surfaces.
Post by andrewdroth » Fri Sep 07, 2018 3:53 pm
Bump!
gilles_3Dreshaper
Full Name: Gilles Monnier
Company Details: Technodigit
Post by gilles_3Dreshaper » Fri Sep 07, 2018 4:15 pm
Hi Andrew,
my proposal would be a workaround as I can see you have the texture option:
  • Create a image made of 1 single color
  • Apply this image as a texture onto your mesh with the Image / Texture material tool
  • Check the option to apply shading on textured meshes (Home / Colors and Aspect tool)
This is only a workaround but I'll make an internal proposal to create an additional representation mode where inside and outside of meshes have the same color
Gilles
3DReshaper Manager
http://www.3dreshaper.com
andrewdroth
Post by andrewdroth » Fri Sep 07, 2018 4:24 pm
Perfect,
Thanks Gilles!
Return to “3DReshaper”
